588,049 active members*
4,058 visitors online*
    Nov 2005
    Heidenhain Itnc530
    Hello
    Can someone help me and tell me if it's NC program is wrong or missing something in maskinkonfigeration, it is a Mikron HPM 600 with Heidenhain control system in tnc530
    Note that the program works correctly in the machine
    my question is why nothing happens in the machine, if I want to use CYCL DEF 7.0 DATE SHIFT I write the Y axis to move 0:05 in relation to the machine zero but for no compensation is performed
    0 BEGIN PGM 100025 MM
    1 ;DATE:05/16/16 09:32:36
    2 ;
    3 ;PRESET #1 VRIDNING NOLLPUNKT
    4 FN 17: SYSWRITE ID 503 NR1 IDX1 =+0
    5 FN 17: SYSWRITE ID 503 NR1 IDX2 =+0
    6 FN 17: SYSWRITE ID 503 NR1 IDX3 =-50
    7 ;
    8 ;
    9 L A+0 C+0 R0 FMAX
    10 ;
    11 BLK FORM 0.1 Z X+0 Y+0 Z-50
    12 BLK FORM 0.2 X+100 Y+100 Z+0
    13 ; OPERATION COMMENTS
    14 ; CHUCKFRONT 19133-00 OP40 MIK412-1025
    15 ; HRNFRS - 50MM TAEGUTEC
    16 M129 M126
    17 ; KYLKANALBORR - 4.3MM STLL VID 4.3MM MIN 45MM UT
    18 TOOL CALL 1403 Z S2650
    19 TOOL DEF 1110
    20 CYCL DEF 247 ORIGOS LAEGE ~
    Q339=+1 ;UTGAANGSPUNKT-NUMMER
    21 CYCL DEF 7.0 NOLLPUNKT
    22 CYCL DEF 7.1 X+0
    23 CYCL DEF 7.2 Y+0.05
    24 CYCL DEF 7.3 Z+0
    25 CYCL DEF 7.4 A+0
    26 CYCL DEF 7.5 C+0
    27 M3
    28 L M140 MB MAX
    29 L X+0.3 Y-198.44 A-90 C+180 FMAX
    30 L Z+19.622 FMAX M28
    31 CYCL DEF 205 UNIVERSAL-DJUPBORR. ~
    Q200=+3 ;SAEKERHETSAVSTAAND ~
    Q201=-8.6279 ;DJUP ~
    Q206=+235 ;MATNING DJUP ~
    Q202=+8.6279 ;SKAERDJUP ~
    Q203=+16.622 ;KOORD. OEVERYTA ~
    Q204=+3 ;2. SAEKERHETSAVST. ~
    Q212=+0 ;FOERMINSKN.VAERDE ~
    Q205=+0 ;MINSTA SKAERDJUP ~
    Q258=+0 ;SAEKAVST UPPE URSPAN ~
    Q259=+0 ;FOERSTOPP.AVST NERE ~
    Q257=+0 ;MATN.DJUP SPAANBRYT ~
    Q256=+0 ;AVST VID SPAANBRYT ~
    Q211=+0 ;VAENTETID NERE ~
    Q379=+1 ;STARTPUNKT ~
    Q253=+70 ;NEDMATNINGSHASTIGHET
    32 L X+0.3 Y-198.44 Z+19.622 R0 FMAX M99
    33 L Z+18.998 FMAX
    34 L Z+19 FMAX
    35 L M9
    36 ; PINNFRS - 5MM MIN 35MM UT NER SLIPAD SKAFT
    37 TOOL CALL 1110 Z S6000
    38 TOOL DEF 1102
    39 CYCL DEF 247 ORIGOS LAEGE ~
    40 CYCL DEF 7.0 NOLLPUNKT
    41 CYCL DEF 7.1 X+0
    42 CYCL DEF 7.2 Y+0.05
    43 CYCL DEF 7.3 Z+0
    44 CYCL DEF 7.4 A+0
    45 CYCL DEF 7.5 C+0
    46 M3
    47 M8
    48 L M140 MB MAX
    49 L A-90 C+120 F5000
    50 FUNCTION TCPM F TCP AXIS SPAT PATHCTRL VECTOR
    51 LN X-16.454 Y-9.5 Z+198.22 TX-0.866025 TY-0.5 TZ+0 FMAX
    52 LN X-14.939 Y-8.625 Z+198.22 TX-0.866025 TY-0.5 TZ+0 FMAX
    53 LN X-11.908 Y-6.875 Z+198.22 TX-0.866025 TY-0.5 TZ+0 F90
    54 LN X-11.36 Y-7.746 Z+198.22 TX-0.8253 TY-0.564695 TZ+0 F290
    55 FUNCTION RESET TCPM
    56 ; FEATURE ID 85
    57 L M140 MB MAX
    58 L M9
    59 L M127
    60 L M140 MB MAX
    61 L X-250 Y+250 R0 FMAX
    62 L A+0 C+0 R0 FMAX
    63 CYCL DEF 7.0 NOLLPUNKT
    64 CYCL DEF 7.1 X+0
    65 CYCL DEF 7.2 Y+0
    66 CYCL DEF 7.3 Z+0
    67 CYCL DEF 7.4 A+0
    68 CYCL DEF 7.5 C+0
    69 CYCL DEF 247 ORIGOS LAEGE ~
    70 L M30
    71 END PGM 100025 MM
    Mar 2016
    326
    Re: Heidenhain Itnc530
    cycle 7 works not incremental and it works in work CS, not in machine CS.
    When You move CS to Y0.05and then move it again to y0.05 it will be the same point. To move it further You need to move it first to Y0.05 and then y0.1. or use parameter and change it's value incremental.
    Compensation makes no difference while moving CS.
    Nov 2005
    Thanks for the help it works now, but I have encountered another problem ifyou can hear me, see this example
    A shaft leans A-90
    It does not work with CYCL DEF 7.0 should have other prametrar the A axis is greater than 0
    18 TOOL CALL 1 403 Z S2650
    * 19 TOOL DEF 1110
    * 20 CYCL DEF 247 Origo læge ~
    * Q339 = + 1; NUMBER UTGAANGSPUNKT
    * 21 CYCL DEF 7.0 DATUM
    * 22 CYCL DEF 7.1 X + 0
    * 23 CYCL DEF 7.2 Y + 00:05
    * 24 CYCL DEF 7.3 Z + 0
    * 25 CYCL DEF 7.4 A + 0
    * 26 CYCL DEF 7.5 C + 0
    * 27 M3
    * 28 L M140 MB MAX
    * 29 L X + 0.3 Y 198.44 A-90 C + 180 FMAX
    * 30 L Z + 19 622 FMAX M28
    Mar 2016
    326
    for working plane angle change You need other cycles like M19 or functions Plane and it's subfunctions.
    If You do it with Cycl 7 You just change the CS, You will not change workplane orientation.
    Mar 2016
    326
    I ment cycl 19 of course.
  1. Problems with HEIDENHAIN iTNC530
    By the-niho in forum DNC Problems and Solutions
    Last Post: 12-25-2023, 09:32 AM
  2. Heidenhain iTNC530 on GROB 550
    By r_searay in forum Post Processors for MC
    Last Post: 05-22-2020, 01:43 PM
  3. HEIDENHAIN iTNC530
    By aliaghaei in forum Drilling- and Milling Machines
    Last Post: 09-10-2018, 07:52 PM
  4. Heidenhain iTNC530 - getting started
    By cdspk in forum Controller & Computer Solutions
    Last Post: 02-20-2015, 08:24 AM
  5. Heidenhain iTNC530
    By Jay Roy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-07-2011, 06:31 PM
