Re: Emco Compact 5 PC and F1 with Welturn/Welmill
I bought my compact with the intent of stripping it down and converting it to mach . The linuxcnc was an easy solution to avoid modifying a complete and functional lathe . Linux can sound a bit intimidating but it's very simple and straight forward to use , and the face of it isn't far off from using windows . One thing for certain is that it can verify if your system is working 100% or not , and aside from adding a couple of files - it is plug and play for the compact 5 . I'd suggest that you try downloading the live disc which you can boot up without having to install it , then you can get a feel for it . Or install it on vmplayer which is a free windows software that allows you to run multiple operating systems without modifying your computer . I don't think vmplayer can control a machine with the control software .
If you want to add cad/cam then that gets more tricky , I personally only use my machine computers for controlling the machines only and I don't add any other programs .
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
