https://youtu.be/lYuVpRZI0cA
https://youtu.be/Jq_4cIcamYo
Homemade Mini Grinder Belt Wheel With DIY Heads Spindle With old motor Hand Drill
Homemade Mini Grinder Belt Wheel Frame here:
And more Materials:
1 pcs motor 50 watt take from old hand drill
1 pcs Mounting L Bracket Mount 42 series Stepper Motor Holder for NEMA 17 Motor
1 pcs BR 6.35mm x 10mm D25 L30 CNC Stepper Motor Shaft Coupler Flexible Coupling 6.35x10mm Motor Connector 6.35*10mm
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
