603,400 active members*
2,630 visitors online*
Results 1 to 6 of 6
    183
    Planetary Gearboxes
    Not sure where to post this but i am looking for 3 planetary gear boxes 10:1 parallel or offset shaft.. anyone have any good sources?
    May 2005
    674
    SDP/SI has them.. https://sdp-si.com/eStore/
    Gearheads -> Planetary
    They come in all the standard NEMA sizes but they're $$$$$$$.
    24260
    If you have the time, I get mine off ebay, Bayside or Alpha Gear.
    Al.
    Albert E.
    Feb 2006
    32
    Typically planetary gearboxes do not have offset shafts. You could save a ton of money if you could use a spur gear. But if you need Planetary in addition to the names above try Mechtrol, CGI, Neugart. They will be marginally lower priced than the ones above
    Sep 2005
    1660
    And Thompson.
    Also, I'm not sure you can get them down in the 10:1 range but Harmonic drives might be another route? See them sometimes on Ebay.
    Jerry
    JerryFlyGuy
    The more I know... the more I realize I don't
    Mar 2004
    261
  1. Reduction gearboxes on servos-good thing?
    By Splint in forum Linear and Rotary Motion
    Last Post: 05-28-2008, 06:32 AM
  2. Cutting a planetary gear...
    By WilliamD in forum MetalWork Discussion
    Last Post: 11-09-2006, 09:56 PM
  3. Planetary Reducers
    By JerryFlyGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 01-28-2006, 08:03 AM
  4. 4th axis- planetary vs harmonic?
    By walter in forum DIY CNC Router Table Machines
    Last Post: 10-03-2005, 04:46 AM
  5. Gearboxes for Steppers
    By vacpress in forum Uncategorised MetalWorking Machines
    Last Post: 07-17-2004, 05:48 AM
