586,117 active members*
3,245 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Probing program for renishaw probe
    Jun 2015
    76
    Hi
    im a rather new user of Fanuc controls, but I have managed to make 4 small probing programs, to find corners with a renishaw probe.
    One for upper left corner, one for upper right corner, one for bottom left and one bottom right. Using the macros from inspection plus and a G10 for zeroing the work offset before running the macros. As I use the probe for zeroing one piece production of parts for stamping tools and moulds.
    is there an easy way to combine programs and call a part of the program with an R value?
    I would like a custom G code, let's say G900R270, and the machine runs the program for upper left corner, so R0, R90, R180 and R270.
    Any help is greatly appreciated.
    I will go to my place of work today to get the programs and post them here.
    I just ordered the book Cnc Programming Using Fanuc Custom Macro B,Kumares C. Sinha,PB, but it will take at least a week before arriving to Denmark.
    the machine is an Matsuura VX-1000 with an Fanuc 31i-model B control, 3 years old, bought with probes and software. But the OMP40-2 touch probe haven't been used before last week, as the dude who has been working with the machine, don't have a basic understanding of programming manually...
    Cheers, Daniel
    Jun 2015
    76
    Re: Probing program for renishaw probe
    Hi did some IF GOTO in this code, will this work?is Macro in Macro possible?
    give thumbs up or down, ill try it tomorrow morning if someone can say that I wont mess up the control:-)
    O9... (G666E..R...)
    #100 = [#8 -53.] ( E = G54-59)
    IF [#18 EQ 0] GOTO 100 (R0 = Bottom Left)
    IF [#18 EQ 90] GOTO 200 (R90 = Bottom Right)
    IF [#18 EQ 180] GOTO 300 (R180 = top Right)
    IF [#18 EQ 270] GOTO 400 (R270 = Top Left)
    GOTO 1000
    N100 (External - Bottom Left + Z)
    G00 G17 G40 G80 G90
    G#100
    M58
    G43
    G10 L2 P#100 X#5021 Y#5022 Z-710.
    G65 P9810 X10. Y10. F3000.
    G65 P9811 Z0. S#100
    G65 P9810 Z10. F3000.
    G65 P9810 F3000.
    G65 P9810 X-7. Y-7. F3000.
    G65 P9810 Z-5. F3000.
    G65 P9816 X0. Y0. I10. J10. S#100
    M85
    G0 M9
    M05
    GOTO 1000
    N200 (External - Bottom Right + Z)
    G00 G17 G40 G80 G90
    G#100
    M58
    G43
    G65 P9810 X-10. Y10. F3000.
    G65 P9811 Z0. S#100
    G65 P9810 F3000.
    G65 P9810 X7. Y-7. F3000.
    M85
    G0 M9
    GOTO 1000
    M30
    N300 (External - Top Right + Z)
    G00 G17 G40 G80 G90
    G#100
    M58
    G43
    G65 P9810 X-10. Y-10. F3000.
    G65 P9811 Z0. S#100
    G65 P9810 F3000.
    G65 P9810 X7. Y7. F3000.
    M85
    G0 M9
    M05
    GOTO 1000
    N400 (External - Top Left + Z)
    G00 G17 G40 G80 G90
    G#100
    M58
    G43
    G65 P9810 X+10. Y-10. F3000.
    G65 P9811 Z0. S#100
    G65 P9810 F3000.
    G65 P9810 X-7. Y7. F3000.
    M85
    G0 M9
    M05
    GOTO 1000
    N1000
    M30
    Feb 2006
    1792
    Quote Originally Posted by Uhrenholt View Post
    It is explained on p.145-147 of the book. It would be helpful if you read chapter 7 from beginning. It would not take much time because you already have basic knowledge of macro programming.
    Feb 2018
    7
    Quote Originally Posted by sinha_nsit View Post
    Sorry I'm new here.
    what is the name of that book?
  1. Renishaw Probing on a 2012 Haas VM3
    By wincoaw in forum Haas Mills
    Last Post: 09-14-2012, 10:57 PM
  2. HAAS OTS Renishaw Probing Issue....
    By Doolie in forum Haas Mills
    Last Post: 09-13-2012, 02:56 AM
  3. Renishaw probing.
    By jpj1474 in forum Mach Wizards, Macros, & Addons
    Last Post: 05-02-2012, 11:18 PM
  4. Renishaw probing -- NON VQC
    By gromit68 in forum Haas Mills
    Last Post: 01-20-2008, 04:34 AM
  5. Renishaw probing setting workshifts
    By Liontastic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2007, 08:25 PM
