Originally Posted by
lamicron
I have also the electonics box isolated from the machine and grounded as you.
Zoltan(from the forum) tells me that maybe i have to much acceleration and speed at the setings, and yes, I rised it yesterday before start, maybe that be the problem.
My cnc is both plasma and oxyfuel, but i dont have yet the solenoid, I was thinking to use a little stepper to make half turn to trigger the oxygen.
I'm going to use a relay to fire the plasma, it is only signal ( the dealer says), because i have a contactor for this issue but only 5 volts to get it on.
Thanks, going to try and let you know
Luis
Unless you have a 3 line torch like the one mounted on my machine you'll have to use either a stepper actuator or a solenoid actuator on the pierce lever itself.
If you use a stepper though you will have to add a 5th axis.
If it works.....Don't fix it!
