[ame="http://www.youtube.com/watch?v=rcjP5A6siSU"]http://www.youtube.com/watch?v=rcjP5A6siSU[/ame]
A video on you tube of the build so far
Good start, Nice to have a machine to cut the parts out with, One machine building a another machine![]()
should get my gecko 540 and 3 axis bipolar motors today , when i do ill take some pictures and post
Woo, if you don't mind, be very thorough with the electronics part (pictures and all), I'm going to get into that in few weeks and I'm a bit terrified, lol I'm going with G540 and Keling's as well.
Don't forget to heatsink the G540, there have been issuse's on the larger amp motors and Gecko just did testing on this issue this week and posted a writeup.
http://geckodrive.com/upload/G540%20...Experiment.pdf
Joe
In his experiment he did not find any difference using a heatsink and using a 120mm fan blowing on it. or use a computer heatsink with fan attached to it, and use adhesive thermo.
I ordered a 120mm 48 volt dc fan to put on my gecko and also got my router and new computer case in today . I will have pictures of the router bed today. I also should have almost everything glued and ready for paint by friday.
what kind of spacers are between the bearing and the angle aluminum on the 06 r2 joes
Looking good troach. Welcome to the Zone!
Nice work, good pics, interesting read. Can't wait to see it run. What motors are you using?
CR.
i got the keling 3 axis gecko 540 kit i think they are 385 oz nema 23 bipolar motors with a 48v/7.5 amp power supply
hey joe what kind of spacers do you have between the angle aluminum and bearing?
bkboggy We wired up some of the gecko serials today and well the pdf and xml at www.geckodrive.com are pretty self explanitory on the wiring and setup for the g540 . if there is any question just ask!
Sweet, hope it all works. I'm going to be wiring mine hopefully in a week.![]()
200 x 10 x TPI = SPI. You must calibrate this in case of mechanical irregularities:
Zero Mach axis DROs. Jog each axis a measured distance. Check that actual travel matches DRO. If it does NOT, then tweak steps up or down as needed. You can use decimal fractions if necessary.
CR.
