586,094 active members*
3,942 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Velox plasma Z axis suggestion for router
    May 2013
    14
    I got the Plasma Z from velox. I saw a few vendors advertised their plasma to be compatible with router application.
    Has anyone with a Velox plasma Z found a good way to fix the floating plate to mount a router? Please share some thoughts and photos.
    Feb 2015
    Re: Velox plasma Z axis suggestion for router
    Don't Velox make a Z axis with a floating head already for plasma?
    - - - Updated - - -
    Seems so: http://www.ebay.co.uk/itm/VELOX-CNC-Plasma-Float-Head-4-5-Z-axis-Linear-Z-ZA450P-/112184331635?hash=item1a1eb50d73:g:NNIAAOxy1klRcZO J
    Jul 2005
    2415
    The floating plate overlaps the rigid plate that the lead screw is attached to and has a couple of keeper bolts in slots to let it slide up and down. I would either see if you can lock it down with those screws or perhaps drill and tap inot the rigid plate underneath and put in a locking screw Then you can attach a router mount to the "floationg plate" and do conventional routing
  1. New build using CNC Router parts, Velox, LM76, 80/20 5 x 10
    By advert in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-20-2016, 11:04 PM
  2. Velox cnc 4x4 cnc router Buying a cnc machine from Velox Cnc.com
    By jdh438 in forum Commercial CNC Wood Routers
    Last Post: 05-09-2013, 05:15 AM
  3. Suggestion for a CNC router!
    By carsonau in forum DIY CNC Router Table Machines
    Last Post: 01-31-2008, 09:24 PM
