586,105 active members*
3,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 4020 motor overload
Results 1 to 9 of 9
    May 2007
    49
    Hi, We bought a Fadal 4020 -1997 yesterday. The machine looks to be in decent shape but with some issues. The previous owner told us he had some problems with the tool changer and when trying to fix it they somehow ended up running the Y-axis to absolute limit ( sounds stupid ). Anyhow the Y-axis was way off and we got several alarms when powering up and was not able to JOG the Y-axis. I shut it down and rotated the ballscrew by hand so the axis got closer to the CS position, but still no movement. If i go to JOG and turn the wheel on Y-axis i see a position movement on the screen but no movement in reality, after a while the machine throws me alarm 26 motor overload. X and Z works without problems.
    Have any of you had this type of problems before? Would really appreciate some help.
    Tomorrow we will swap drivers with X-axis and try again.
    Thanks.
    OviksNC/Sweden.
    Mar 2008
    683
    Re: Fadal 4020 motor overload
    Sounds like a dead amp. Good luck.
    May 2007
    49
    Quote Originally Posted by warrenb View Post
    Hi. Switched the amps between X and Y but still the same problem. Maybe the motor is bad? We have measured the motor but i shows nothing wrong there.
    OviksNC/Sweden.
    May 2007
    49
    Ok found the problem with the Y-axis. The previous owner had accidently pulled a cable to the controller card for the Y-axis, causing the alarm. So that was easy! With the Y-axis working we found the original problem, and probably the reason for all the cable pulling of the previous owner
    The ATC 22 tool umbrella has it´s own life. First when we typed TC,1 the ATC went to spindle side and spindle released tool clamp and went up. Pushed CCW on the umbrella and it began spinning like crazy and quickly after throw ATC Turret alarm and we had to Cold start the machine again. We found that the hall sensor that reads the umbrella rotation ( small shaft with a magnet ) was broken. Ordered a new one and installed it today! now the umbrella spins about 9-10 slots in normal speed after one push on the CW/CCW button and then gives the alarm ATC Turret failure. Do anyone know how to reset the ATC, how do we know when its in T1, T2 etc? Is there any instructions for doing this?
    Thanks in advance.
    OviksNC/Sweden.
    Jan 2015
    417
    Any pocket can be T1 so which ever tool you want to be 1 in the enter next command type SETTO enter
    Jan 2015
    417
    I think you have to adjust the hall effect sensor from the ENTER NEXT COMMAND type DI enter and then DS to display your switches (see picture) The one that says ATCTURRET when you hit the Turret button you will briefly see 01 (reads the Magnet) if you dont see the 01 then you need to get the sensor closer to the magnet. after your done type X to exit the switches screen
    Jan 2015
    417
    For all the Fadal Manuals FREE go to Fadal Manuals | ItsCnc.com
    May 2007
    49
    Quote Originally Posted by rodney247 View Post
    Thank you! We have only mesured the sensor with instrument when turning the motor by hand so that the magnet is passing the sensor.
    Could it be an old program in the background causing problems? I have a message ( tool no.5 in spindle ) it says and have not come to the part that i learned all commands on the controller yet. I tried a simple M6 T0 but nothing.
    OviksNC/Sweden.
    Jan 2015
    417
    at ENTER NEXT COMMAND prompt type SETTO enter it will make the tool in spindle and the current pocket Tool 1.
    to see many of the Commands in the control type MU enter
    DI enter
    DS enter Displays the Switches. you must see the 01 at the ATCTURRET when the magnets passes otherwise it will not stop indexing
    here is the manual for the FADAL ATC you have http://itscnc.com/images/Automatic_Tool_Changers.pdf
  1. Replies: 1
    Last Post: 07-24-2015, 06:15 PM
  2. Fadal 4020
    By joshuac in forum Fadal
    Last Post: 09-10-2010, 11:36 AM
  3. Fadal 4020 Z axis motor overheat
    By dmac88 in forum Fadal
    Last Post: 09-28-2009, 02:51 PM
  4. 2003 Fadal TRM Motor Overload
    By TriumphMachine in forum Fadal
    Last Post: 09-22-2009, 12:51 AM
  5. How do I tell the age of a FADAL 4020?
    By Rickady in forum Fadal
    Last Post: 07-10-2007, 12:02 PM
