588,500 active members*
4,656 visitors online*
    Dec 2006
    17
    mill/turn on a cin turn
    I am having a problems with my lathe, it seems that i can not get the feed rate right using a g93. i'm cutting a simple d groove on the part using a t-cutter. My problem is, that the spindle will fly when i don't have a x move with the c axis in the same line. And when i do have them in the same lines the cut looks like it is jagged. Can anyone out there can help? Please!!!
    thanks
    <!-- / message --><!-- sig -->__________________
    Rob Timby
    <!-- / sig -->
    <!-- controls -->
    Rob Timby
    Feb 2006
    992
    Post your program we might see something.
    The best way to learn is trial error.
    Dec 2006
    17
    Program For Cinturn
    newtexas2006,
    Here is the program i'm using in the lathe to mill the groove, any ideas?
    (PGM, RAYGROOVE DATE 29-01-07 TIME 16:29)
    :G0G62G70G97S76M3G95F.003T2M26X10.Z10.
    (MSG, TOOL - 2 OFFSET - 0)
    (MSG, 1-1/4 SLOT ENDMILL)
    G0X10.Z10.
    M21
    G0X0.Z1.
    C0.
    G94G97S500M13F3.
    X1.3559Z.1
    G93G1Z-.85
    C-24.804F2000.
    X1.3957F3.
    X1.4469C-19.868F3.72
    X1.5085C-15.267F3.44
    X1.5719C-11.437F3.17
    X1.6419C-7.921F2.91
    X1.6652C-6.716F2.88
    X1.6846C-5.448F3.03
    X1.7C-4.13F3.15
    X1.711C-2.774F3.24
    X1.7177C-1.393F3.3
    X1.7199C0.F3.33
    X1.7255C4.623
    X1.7423C9.191F3.28
    X1.77C13.655F3.2
    X1.8083C17.973F3.08
    X1.8418C20.95F2.96
    X1.8801C23.815F2.85
    X1.8856C24.278
    X1.8889C24.757F2.97
    X1.89C25.244F3.03
    X1.8899C154.756
    X1.8888C155.243
    X1.8854C155.721F2.97
    X1.88C156.182F2.86
    X1.8271C160.271
    X1.7844C164.545F3.02
    X1.7523C168.975F3.15
    X1.731C173.521F3.25
    X1.7209C178.135F3.31
    X1.722C182.766F3.33
    X1.7343C187.362F3.3
    X1.7576C191.873F3.24
    X1.7916C196.254F3.13
    X1.8319C200.127F3.
    X1.8801C203.815F2.86
    X1.8856C204.278
    X1.8889C204.757F2.97
    X1.89C205.244F3.03
    X1.8899C334.756
    X1.8888C335.243
    X1.8854C335.721F2.97
    X1.88C336.182F2.86
    X1.8272C340.271
    X1.7845C344.546F3.02
    X1.7523C348.976F3.15
    X1.7311C353.521F3.25
    X1.7228C356.751F3.31
    X1.72C360.F3.33
    X1.7245C364.157
    X1.7381C368.27F3.29
    X1.7419C369.643
    X1.7412C371.02
    X1.7361C372.389F3.27
    X1.7265C373.737F3.22
    X1.7126C375.053F3.14
    X1.6946C376.323F3.03
    X1.6326C380.594F3.08
    X1.5809C385.132F3.3
    X1.5399C389.906F3.5
    X1.5143C394.069F3.66
    X1.4968C398.356F3.76
    G0Z1.
    G0X10.Z10.C0.
    M20
    G12
    M0
    M02
    Thanks for the help
    Rob Timby
    Feb 2006
    992
    I think G93 make your machine move funny. If I remember it right G93 is feed degree per minute. And if you look at the program line by line on Cxx.xxxx the degree is increment unevenly, and I think that is why the machine move the way it does.
    Why don't you use G12.1 and use feed per minute(G98).
    Dec 2006
    17
    newtexas2006,
    I dont understand what you mean by increment unevenly on the c. I know the machine reads not degrees per min but in seconds per min. The guys at cin gave me an equstion time= distance(60)/fpm. This is what i had my post post out using a g93. I will try a g98 and a g12.1 tomorrow when i come in
    rob
    Rob Timby
  1. Cin Turn turn/mill
    By Robert Timby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2007, 02:12 AM
  2. Haas mill/turn.
    By CNCtoday in forum Haas Mills
    Last Post: 10-04-2006, 12:22 AM
  3. Surfcam mill/turn
    By CNCRim in forum G-Code Programing
    Last Post: 07-23-2006, 04:42 PM
  4. Sharing one Comp for Mill and Turn?
    By DennisCNC in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2006, 03:23 AM
