Trying to set up aspire to carve a board with both ends raised up, one through lamination, the other an angled scarf joint. Problem is I don't see a way to tell aspire the shape of the work piece, so instead I have it set up as one big block, where the cnc will end up making a lot of useless passes cutting air. Take a look at the attached image for a better description. I'm using aspire 3--is there any way to do this that won't take 90 hours? I can carve one by hand in a whole lot less time than that!
http://i.imgur.com/uXtK4K4.jpg
