603,340 active members*
4,011 visitors online*
Results 1 to 10 of 10
Hybrid View
    May 2012
    23
    Question Limit Switch Wiring
    I purchased a 3 Axis CNC Stepper Control Box, Digital Stepper Motor Driver, 110VAC/220VAC for my G0704 High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Prin It has what appears to be a DB9 connector on the rear of the control box labeled limit switch. The control box is advertised as X, Y, Z limit switch wired.
    I opened the control box and the following explains the wiring from the breakout board to the DB9 connector;
    P13 connected to pin 1 on DB9 connector with a red wire
    P12 connected to pin 4 with a black wire
    P11 connected to pin 3 with a red wire
    P10 wire connected to E-stop
    P15 connected to pin 2 with a black wire
    GND connected to pin 5 with a black wire
    Nothing connected to pins 6 – 9 of the DB9 connector
    Attachment 326796
    BOB wiring diagram at the bottom of link: KL-DB25 Opto-Isolated Breakout Board Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Printers For Sale
    I want to utilize the following proximity switches for X, Y, Z
    A60 - INDUCTIVE PROXIMITY SWITCH
    How do I connect multiple switches to the DB9 connector on the back of the control box? I attempted to contact the company and post on their forum on this site without any answers. Thank you.
    Nov 2009
    4415
    Limit Switch Wiring
    What is the problem? Did you look at the wiring diagram on the CNC4PC site?
    The switch will run on 5-24v. The board is 5v. Should be a piece of cake.
    Pins 10-13 are input pins.
    A lazy man does it twice.
    May 2012
    23
    Re: Limit Switch Wiring
    Quote Originally Posted by Fastest1 View Post
    Like I said in my initial post, the BOB is already wired to a DB9 connection (maybe not the right name for the connection) on the back of the control box. It was purchased as a prewired setup/essentially plug and play. The problem is what will allow me to connect the switches to that existing connection? If the switches will have to be wired to the BOB, what is the point of the connection on the control box labeled limit switch if it can't be utilized as the connection point for switches?
    Mar 2007
    2083
    Hi Ron2d
    your BOB and proximity switches with PNP outputs are not the easiest combination get to to work together
    the diagrams from Keling are for the C10 BOB with the jumper set to select pull down resistors on the inputs
    without the circuit diagram of the KLDB25 or a board to examine I have to make a few assumptions
    1) assuming the volt drop across the LED in the opto isolator is 2v
    2) the LED's current limiting resistor is 300 ohms
    there for when an input is grounded 10mA will pass through the LED
    so the light the LED emits switches ON the NPN transistor inside the opto isolator - the transistor will then ground your PC's printer port input pin
    since the A60 proximity switch PNP output is either connected to the positive supply or open circuit when the limit is detected
    if you have the A60 switches one simple solution could be to add a 50 to 100 ohm resistor between the BOB's input and ground
    when the switch output is open the current through the opto-isolators LED and the added 50 ohm resistor will be 8.5 mA and should be enough to switch the opto isolators NPN output ON
    when the proximity switch connects the BOB's input to +5V a current of 100mA will flow through a 50 ohm pull down resistor to ground
    connecting two or more proximity switches will need more thought as the minimum supply required by the proximity switches is 5V
    depending on how many switches are wired in series the supply to the first switch needs to be high enough to ensure the last one in the chain works but care has to be taken not to pull the BOB's input higher than +5.5V !!!
    John
    May 2012
    23
    Considerable differences (e.g., Fastest1 indicating this should be easy/piece of cake in comparison to john-100 who is describing a more complicated scenario is just one example) in-terms of wiring have made this part of the process frustrating to say the least. I purchased a prewired control box to avoid this type of hassle. I have multiple A60 proximity switches, but don't really know what approach to take now.
    Mar 2007
    2083
    Hi Ron2d
    what power supply has been fitted in your control box to supply the BOB's power to terminals VDD and GND ?
    you may be able to add a wire to connect the positive supply to one of the unused pins on the DB9 connector to save having to use another supply for the proximity switches
    then the only extras you need are the three pulldown resistors ( one for each axis - 51 or 56 ohms will be easier to find in the likes of Tandy/Radio Shack )
    John
    Attachment 326888
    PS
    C10 BOB wiring
    (part of diagram from CNC4PC)
Name:	A60 switch and C10 BOB wiring.jpg
    May 2012
    23
    I was told to wire the A60 proximity switches in series based upon the following link as a reference. http://cnc4pc.com/Tech_Docs/A60_C10A.JPG My BOB is a KL-DB25 and not a C10. I went into ports and pins configuration of Mach 3: enabled homes for x, y, and z, made sure port number is correct, and entered appropriate pin number. Active low initially had x's for all three which resulted in yellow lights for M1home, M2home, and M3home in the diagnostics page of Mach to immediately light up, so put a check mark for all three active low which turned the yellow lights off. The proximity switches have their own light on each of them that remain lit until turning off when close to metal. However, upon testing the switches near metal no lights come on in the diagnostics page of Mach for M1home, etc. to indicate they are functioning correctly. For example, when the E-stop is pressed the respective red light on the diagnostic page lights up to indicate that function has occurred. What else should be checked and/or possibly changed? I am utilizing a UC100 USB motion controller if that matters. Any help would be appreciated.
    Mar 2007
    2083
    Hi Ron2d
    you do have a multimeter to check the voltage at the breakout boards inputs don't you ?
    with one wire connecting the E-Stop to P10 and an another wire connecting the second E-stop terminal to GND
    your meter should see the voltage between GND and input P10 switch between 0V and +4 to +5V
    as you operate the E-Stop switch
    with the limit switches / proximity switches operating correctly you should see the same change in voltage on the other inputs you have used
    with micro switches connected between GND and an input its easy just copy how the E-Stop is wired but
    with the PNP proximity switches it will only work when you add a pull down resistor as your BOB does not have that option - the C10 BOB does
Name:	A60 proximity switch and KL-DB25 BOB.jpg
    PDF manual
Name:	6 axis breakout.pdf
    John
    PS
    from the web
    OK for microswitches
Name:	BOB wiring.jpg
    PPS
    top of BOB PCB
Name:	BOB PCB top.jpg
    possible circuit of 6 axis BOB - photos on web are not a higher enough resolution to be 100% sure
Name:	possible 6 axis BOB circuit.jpg
    May 2012
    23
    John, I appreciate you taking the time in an attempt to assist me. It sounds like micro switches would be a better option in-terms of ease of wiring and compatibility (i.e., not requiring resistors) with my BOB. I will probably just return them and purchase micro switches instead. Thanks again for your help.
    Mar 2007
    2083
    Hi Ron2d
    micro switches are the simple solution to get you going
    at a later date you can always look again at using proximity switches
    for you and any one else finding this thread
    I have a two more diagrams for the KL-DB25 optically isolated Break Out Board
Name:	3 axis control box DB9 wiring for microswitches.jpg
Name:	3 axis control box DB9 wiring modded for A60 switches.jpg
    note - the 56 ohm resistors need to be 56ohm 1/2W
    better still 56 ohm 1W
    John
    Attached Thumbnails Attached Thumbnails 3 axis control box DB9 wiring modded for A60 switches.jpg
  1. Limit switch wiring
    By rstrease in forum Gecko Drives
    Last Post: 04-17-2015, 05:02 PM
  2. Does limit switch wiring have to be shielded
    By ozydel in forum Benchtop Machines
    Last Post: 01-02-2015, 06:22 AM
  3. New Limit Switch Wiring Slide
    By EKFER in forum CNC Machine Related Electronics
    Last Post: 09-20-2014, 02:41 AM
  4. Limit Switch Wiring
    By The Speaker Guy in forum CNC Machine Related Electronics
    Last Post: 01-07-2007, 11:11 AM
  5. Limit & Home Switch Wiring?
    By Willyb in forum Gecko Drives
    Last Post: 10-17-2005, 10:02 PM
