587,518 active members*
3,331 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Cut "deep" corners for a pocket? Square peg into a round hole!
    Jul 2016
    Recently started using SolidCam for a hobby CNC router.
    Cutting a rectangular pocket of course leaves rounded corners.
    Is there an option in SolidCam to cut deeper into corners?
    This way a 1'x2" rectangular pocket will truly receive a 1'x2" rectangular peg, not counting the tolerances, etc...
    Example is the two bottom corners in the attached image. Blue outline is the original rectangle pocket.
    Feb 2007
    711
    Re: Cut "deep" corners for a pocket? Square peg into a round hole!
    Just update your geometry to match reality. Any reason not to?
    Jul 2016
    That is certainly an option, was hoping there is a SolidCAM option.
    The only problem is that it is no longer "parametric". The size of the dog-bone (the notch) should change based on the size of the bit / mill used.
    Jun 2003
    1365
    Draw it how you want it, its quite simple.
    Jun 2011
    152
    It would be nice, but I just add it to my geometry when I create a part as others have suggested.
    Richard
  1. Round linear bearings v "square"
    By stevenj in forum DIY CNC Router Table Machines
    Last Post: 01-23-2016, 11:25 PM
  2. How to "Drill" a 1/2-20 thread hole 1" deep on a Tormach in Ti-6Al4V
    By ChrisPhoenix in forum Material Machining Solutions
    Last Post: 07-18-2015, 01:05 AM
  3. Replies: 7
    Last Post: 10-20-2013, 03:12 PM
  4. best way to make a 1mm dia. hole 3/8-1/2" deep?
    By Chriseg1 in forum Haas Mills
    Last Post: 10-06-2011, 05:20 PM
  5. boring a .875" hole 3" deep in 304SS
    By mc-motorsports in forum MetalWork Discussion
    Last Post: 04-15-2008, 08:57 PM
