603,942 active members*
3,334 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco bmc2416/dsm atc error
Results 1 to 8 of 8
    Jun 2015
    9
    Hy. how to adjustment of atc height?
    Jun 2008
    1111
    Re: Hurco bmc2416/dsm atc error
    If version 2 software, Auxiliary enter 100 enter to get to service page. Go to machine setup then go to toolchanger diagnostics. Press more key until store t/c height is displayed then press when at the correct height to store it.
    Jun 2015
    9
    step by step be? It failed to enter on this basis:ADJUSTMENT OF ATC HEIGHT
    ULTIMAX II, 32, ULTIMAX 3 MB MACHINING CENTERS
    MAX2 8.50 to 8.6 & MAX3 SOFTWARE
    Problem description:
    Tool changer not at correct height.
    1. Calibrate Axis and Tool changer. Orient Spindle. Set Current Tool to "0". Start ATC Diagnostics (this is done in Manual Mode) by depressing ATC Diagnostics Softkey, then depress Machine Diagnostics Softkey.
    2. Ensure Z Axis is fully Calibrated, then depress the Magazine Right Softkey then Start button. Next you will enter the "Secret Code". Do this by pressing "Enter, 1,0,1, Enter ". Carefully jog the Z axis down with the Jog Hand Wheel, to obtain .5" between the bottom of the "V" Flange located on the Tool Grippers and the bottom of the spindle nose. Refer to figure below
    3. The CRT displays Z Axis position, i.e.; (Z Axis) 0.0000 (TARGET) 0.0000. Target is previous value if any. Press Store Z Softkey. This records the Z Axis's present position as the new Tool Change Height. Check at this point that (Z AXIS) equals (TARGET) and AT HEIGHT is back lit. Press Exit Softkey.
    4. To test your adjustments, jog head up and move magazine to the left. Place tool into spindle. Now jog Z Axis down until "AT HEIGHT" is back lit, then move magazine to the right. Watch for smooth engagement of tool changer and tool. If tool magazine wants to move up or down adjust Target Value as described above.
    5. Record value in "TARGET" for future reference.
    6. Run Tool Changer in auto mode to test operation.
    Jun 2008
    1111
    That is the description for Max 2. We didn't do a 2416 before Max 3.
    Jun 2015
    9
    Unfortunately, as it turned out it was built machine.plc loose
    Jun 2015
    9
    Hy Auxiliary enter 103 enter.
    Jan 2017
    24
    Maybe some one have 2.16 software for hurco 2416, i can share i have older soft 2.15 in that no industry standart
    Aug 2024
    Bloke
    I have a 1998 24/16 SSM with this very same issue , I followed your directions on resetting the T/C height to no avail , this error message wont let me calibrate the machine, could this be the problem ? I in boxed you with a couple other questions, not sure if your inbox is full. appreciate any help you could give me. Thank you.
  1. Replies: 2
    Last Post: 01-11-2015, 05:22 PM
  2. looking for Hurco VM1 or BMC2416
    By Vermontcnc in forum Want To Buy...Need help!
    Last Post: 06-25-2012, 08:58 PM
  3. Hurco KM-3P Boot Error
    By nuzmeed in forum HURCO
    Last Post: 08-18-2011, 06:53 AM
  4. Hurco BMC2416 tool change problem
    By Farrell3S in forum HURCO
    Last Post: 12-29-2008, 06:14 AM
  5. Hurco ATC error
    By openforbiz in forum HURCO
    Last Post: 11-05-2007, 04:19 PM
