586,233 active members*
3,157 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Tool height check, grounding through spindle bearings
    Nov 2007
    7
    I purchased a tool height contact unit for my router and it requires either an alligator clip on the tool or ground through the bearings of the spindle. Since I want this to be an automatic operation at the beginning of each program I prefer the later. Anyone know of any problems running the 5v signal through the spindle bearings? is this the industry standard? thanks
    15362
    Re: Tool height check, grounding through spindle bearings
    Quote Originally Posted by lgr View Post
    It most likely won't be very reliable, it is best to add a Brush, to run on the spindle up at the top is the best place, this is also a good idea to get a longer life from your Bearings, something like this can be quite small
    Mactec54
    Jan 2011
    188
    the 5V doesn't flow through the bearings - the bearings (or alligator clip) are always grounded - the tool setter is an open contact which floats at 5V by way of a weak pullup resistor - when the grounded spindle makes contact - the tool setter contact becomes grounded - during which time 5V flows through the pullup resistor - works reliably in my experience -
    in some tools the bearings may be mounted in a plastic housing or rubber boot (insulated from ground) - in that case you could improvise some sort of reliable connection from the outer bearing case to ground (same effect as using a grounded alligator clip)
    www.signtorch.com
    Jan 2008
    241
    I'm trying to do just this, but its not working.
    It worked GREAT on my old Bosch Colt. Now I want to implement it on my new 600w spindle.
    I've got the parts made up, and thinking it would be a straight plug and play, it's not.
    Seems like it is electrically interfering (shorting out) with the other electronics.
    I have no resister in line, and honestly, not sure of the polarity (Going to double check tonight)
    But if I can get this working. its a supper set up!
    I have some pictures, but can't seem to get them uploaded.
    I'll try uploading them again later(might be a work computer thing)
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
  1. Grounding router spindle?
    By Mogal in forum DIY CNC Router Table Machines
    Last Post: 02-07-2022, 07:32 PM
  2. Replies: 2
    Last Post: 03-02-2017, 01:54 PM
  3. Grounding a 2.2kw VFD spindle
    By DDMODS in forum Spindles / VFD
    Last Post: 07-21-2016, 11:28 AM
  4. Replies: 1
    Last Post: 03-04-2014, 01:08 AM
  5. How to check wear on Biesse Rover 322 XYZ rail bearings
    By dengler in forum Maintenance DIY Discussion
    Last Post: 11-19-2012, 04:23 PM
