586,042 active members*
3,727 visitors online*
Results 1 to 8 of 8
    Aug 2016
    4
    MKX-4 Mach3 don't work slave axis home
    Card MKX-IV. If the axis A configured slave from the Yaxes, when pressed “Ref all Home” Mach3 does not respond to the switch Ahome only switch the main axis. Don't work A axis home.
    Mach3Mill.xml: https://yadi.sk/d/48R5yb4YtrH2n
    Re: MKX-4 Mach3 don't work slave axis home
    Contact the card manufacturer and ask if there plugin supports slaved homing.
    Aug 2016
    4
    The manufacturer not answer.
    A similar problem on two cards purchased in different places.
    Slave A_axis stops along with Y_axis (switch YHome).
    It is imposible to correct skew of the axis(((
    Make sure that "Home Slave with Master" in General Config is NOT checked.
    Aug 2016
    4
    Thanks for your answer.
    Yes: "General Config"->"Home Slave with Master" is not checked.
    If A_axes is not slave, all 4 home swiches works good.
    Sounds like the plugin does not support slaved homing.
    Aug 2016
    4
    You are right, the plugin works incorrectly. View time when triggered "A Pos" led'
    https://youtu.be/BaBQIyiBmOM
    Nov 2017
    9
    Hello
    I have the same card mkx-IV driver v2.39.9 and mach3.
    Have you been able to solve your problem?
    I have a switch on each motor of my axis (Y & A).
    Axis A is slave to the Y axis.
    When I run a RefHome RefHome (2),
    1- Y and A move together until touching switch Y.
    2- Y and A stop
    3- Nothing happens but I have to trigger switch A by hand.
    4- Y and A go back.
    If I resume the step by first releasing the switch A
    1- Y and A move together until touching switch A.
    2- Y and A do not stop
    3- I trigger the Y switch by hand.
    4- Y and A stop
    5- Y and A go back.
    An idea of ??why this behavior?
    MyShop
  1. Mach3 Slave Axis problem
    By Darian S in forum DIY CNC Router Table Machines
    Last Post: 07-31-2014, 04:06 PM
  2. Slave Axis and offset home switches
    By lthall in forum Machines running Mach Software
    Last Post: 12-24-2013, 02:31 PM
  3. G540 + Mach3 Slave Y & X axis
    By dglasco in forum Gecko Drives
    Last Post: 09-28-2013, 10:23 PM
  4. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
  5. Replies: 8
    Last Post: 10-29-2009, 02:09 PM
