586,108 active members*
3,107 visitors online*
    May 2016
    14
    return to zero - not always
    I have a Mori Seiki SL-3 with Yasnac LX1 controller. Most of the time it works well. But, sometimes I get an error when it tries to return to zero. The problem is always in the X direction. Rather than the normal green light, I get a positioning alarm. At first I thought it might be a sticky switch, but the tricky part is, the only way I've found to make the problem go away is to completely shut down the machine and bring it up again. No amount of jogging away and running at it again will work. I have to shut down and restart. Your thoughts are appreciated.
    Jan 2015
    42
    Re: return to zero - not always
    My name is Bob. Email me at [email protected]
    You need to try to adjustment
  1. 10m zero return
    By vpmachine in forum Fanuc
    Last Post: 08-12-2012, 12:31 AM
  2. z return
    By Clyde_06 in forum Surfcam
    Last Post: 11-16-2011, 06:45 PM
  3. Zero return
    By bubba107 in forum EMCO Mills
    Last Post: 10-22-2009, 01:49 AM
  4. Return to Zero
    By mikemill in forum Machines running Mach Software
    Last Post: 08-25-2009, 08:47 AM
