586,117 active members*
3,470 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Problem plasma cutting circles
Results 1 to 7 of 7
    Aug 2016
    6
    Hi new here, using a Swiftcut 4x4 cnc plasma table-Hypertherm 105 machine, I usually cut 1mm-1.2mm ss and 10mm ss, for some reason when i cut a circle in the 10mm ss, I am not getting a clean cut, a little bit is left uncut, so a hammer is needed, very annoying, the table was bought new and has had little use, it cuts thin ss perfectly. any ideas?
    Cheers Dave
    Oct 2010
    156
    Re: Problem plasma cutting circles
    The stainless steel doesn't cut as "easy" as mild steel. It takes more force. I would run the torch a bit longer past the start point along the profile cut path or, at least, slow down the feed a little in an attempt to give the bottom of the material a chance to catch up and get cut. The thicker the material, the more this would show up.
    HTH
    Paul
    Aug 2016
    6
    Hi Paul Thanks for the reply, I think the over burn is set at 2mm, would 3mm be better?
    Cheers Dave
    Oct 2010
    156
    Hi Dave,
    I have cut mostly 1.5mm and, like you already know, it cuts fine. I haven't had the opportunity to cut stainless as thick as 10mm, but I would try 3 or 4mm.
    Good luck. I would be interested to know what works best.
    Paul
    Aug 2016
    6
    Hi Paul I will try it and let you know, I need to cut some flanges out of 10mm ss shortly for a job
    Dave
    Nov 2012
    64
    Yes I get that on stainless and even on ms over 10mm but mines only a powermax 45, what I do is add a slowdown rule in sheetcam, around 2.5 seconds before end set feed rate to 50%, overburn doesn't help me at all for that problem, it when you crossover the leadin where the problem is, the arc seems to skip across leaving the tag, slowing down in just the right spot catches it, it takes a little trial and error.
    Aug 2016
    6
    Quote Originally Posted by Kerryfisher View Post
    Hi Thanks for the reply, I have had the table serviced by the manufacturer, the engineer found a fault with one of the printed circuit boards, it cuts like it did when it was new, very happy
    Cheers Dave
  1. Is anyone else having problem cutting circles?
    By FoxCNC1 in forum Avid CNC
    Last Post: 04-22-2017, 11:07 PM
  2. Problem: Shaky / stepped arcs & circles mach3 plasma
    By snowdaze in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-27-2016, 07:36 PM
  3. Replies: 0
    Last Post: 03-06-2015, 06:17 AM
  4. Problem cutting circles
    By gateman in forum Uncategorised MetalWorking Machines
    Last Post: 12-23-2013, 05:18 AM
  5. Problem cutting circles - arc shifting issue
    By pkuhns in forum DIY CNC Router Table Machines
    Last Post: 08-16-2010, 12:45 AM
