587,518 active members*
3,407 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Tormach Controller or PathPilot Clone for PCNC 440
Results 1 to 12 of 12
    Jan 2014
    12
    I'm trying to have to avoid the tormach controller for my new 440, but I'm unsure how much work it is to get a PathPilot setup on a conventional PC.
    If I have:
    PathPilot tested motherboard
    compatible processor
    and PP770-UPGRADE - PathPilot™ Upgrade (Part# 35458)
    will it basically work right out of the box, or do I have to mess around with MESA firmwares etc?
    Oct 2010
    1189
    Re: Tormach Controller or PathPilot Clone for PCNC 440
    In Short it will be binary it works or Not use the cd you have put the Mesa Card in and give it a try if it works Perfect if Not you Need some help which you might find in some Forums ,..
    Gesendet von iPad mit Tapatalk
    May 2009
    29
    PathPilot is now windows and will search for the mesa card. there are two types, one pci & the other pci-e, you order from Tormach the one whits you need.
    Jan 2014
    12
    So there is no reason to buy a tormach controller at all then?
    I'll get he PCI version from tormach, but there is no need to edit the .ini or hal files then right?
    what is the difference between the 770 and the 1100 upgrade kits?
    Dec 2008
    740
    Quote Originally Posted by andyf97 View Post
    PathPilot is now windows ...
    Windows??? What do you mean by "is now windows"?
    Step
    Dec 2008
    740
    Quote Originally Posted by MadGumby View Post
    ...what is the difference between the 770 and the 1100 upgrade kits?
    From what I can see the only difference is the version of the manual provided.
    Step
    Jan 2014
    12
    So if I have the Mesa 5i25 card, compatible motherboard and processor, I can install pathpilot from the 770 upgrade kit and it will allow me to select 440 as an option and it'll just install those drivers and config files?
    Dec 2008
    740
    That's what I did. I'm using a Gigabyte GA-H81M-HD3 (from the list of tested motherboards) with an Intel Dual Core Pentium G3260/3300.
    All machine types can be loaded from the PathPilot software:
    Step
    Sep 2009
    624
    There's a very good reason, but you may conclude it's not good enough.
    Tormach supports the Tormach controller. If you have a problem with their controller, they'll be with you until it works right. If you don't have a Tormach supplied controller, you're responsible for it. Tormach almost never leaves you hanging, but if you have a computer/controller problem with a non-Tormach controller, you may hit a point where you're on your own, or where the best advice you can get is that it seems to be a controller problem. At which point, you're the support. As long as you're clear on that, OK with it, and won't complain if it happens, you'll be fine with a non-Tormach controller.
    That's exactly what happened with my M3 controller, which was non-Tormach. It got goofy. Tormach was great, but it just got strange -and almost had to be having a hardware problem. Easy decision, I switched to PP, I bought the hardware from Tormach. That turned out to be an even better decision when I had sporadic (and hard to pin down) hardware problems with the new controller. Tormach just fixed it.
    Your call. You'll get great support either way.
    Jun 2006
    3063
    Quote Originally Posted by TurboStep View Post
    Step
    He probably meant "is *not* Windows". The more typos the greater the chance it is someone using a smartphone to reply and sometimes they can be a real hoot.
    Dec 2008
    740
    Quote Originally Posted by MichaelHenry View Post
    Well spotted
    Step
    (Sent from my "smart"phone)
    Jul 2004
    1424
    Quote Originally Posted by GLCarlson View Post
    There's a very good reason, but you may conclude it's not good enough.Tormach supports the Tormach controller....That's exactly what happened with my M3 controller, which was non-Tormach. It got goofy.
    Path pilot seems to be more reliable, and we have heard from dozens of people that have had no problem using there own computer, and only two who did have problems. And that was because their mesa card came with the wrong jumpers. The Mesa rep on this forum solved their problem.
    IMHO, use your own computer. Spend the money you save on more tooling. Shipping from Tormach is expensive, so making a bigger order saves you money in the future.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  1. FYI: Tormach tested PathPilot Motherboards
    By NMay in forum Tormach PathPilot™
    Last Post: 06-21-2017, 04:41 PM
  2. non-Tormach Touchscreen with PathPilot
    By beunks in forum Tormach PathPilot™
    Last Post: 01-02-2017, 09:14 PM
  3. Non-Tormach PathPilot users in Australia
    By GusBiz in forum Australia, New Zealand Club House
    Last Post: 07-19-2016, 12:25 AM
  4. Which breakout board for Non-Tormach Pathpilot?
    By Nigel Tufnel in forum CNC Machine Related Electronics
    Last Post: 04-25-2016, 09:25 PM
  5. Tool Offset Settings in the Tormach w/ PathPilot
    By quarky42 in forum Tormach PathPilot™
    Last Post: 03-07-2016, 04:11 AM
