586,655 active members*
3,210 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    Nov 2015
    43
    Bens convert mdf CNC to plywood
    Hi, i bought a hobby build machine a few years ago and havent used it for a while, It is very sloppy and I tried to tighten it up a bit ,and that may have been a mistake as some MDF delaminated.
    The main reason i havent used it much is the noise aspect.
    At some stage i would like to build a shed or enclosure with some soundproofing....
    but anyways MDF machine has three motors , nema 23 or 24?, leadcrews, , aluminum angle with skate bearings for motion, electronics are gecko i think
    one of the problems is the guy who built it took a smaller design and scaled it up without beefing it up enough.
    also there is no way to adjust the contact between skate bearing and rails,
    I contemplated trying to build machine with t-slot or supported rails, but i think that a better design uses two Y-motors and i could work out how to alter electronics, or alternatively 3 motors could be good for moving bed design , but this would waste long Y- leadscrew that i have.
    as such id try to see if i can improve machine by improving structure slightly (thicker plywood, more skate wheels (wider bearing on rails), a way to tighten bearing again rails, and tenon box for bed.
    so at the moment i have built bed, and have sketchup design nearing completion
    machine is about 1200 x 600 - hoping to get 900 by 450 cutting area
    Nov 2015
    43
    Re: Bens convert mdf CNC to plywood
    Nov 2015
    43
Name:	plywood for making cnc 15.jpg
    Nov 2015
    43
    Nov 2015
    43
    this is the MDF machine - note my attempt to stiffen up sides of gantry - originally only 10mm mdf sides
    Nov 2015
    43
    im cutting some pockets out with current machine, but will cut outline with jigsaw or table saw
    surprising it can cut at all given the sloppiness of structure MDF machine- gentle pressure moves router at least 5 mm
    Nov 2015
    43
    this is the base of the plywood machine im building
    Looking good. Keep the photos coming!
    BrianV
    WoodWorkerB
    HobbyCNC.com, WoodWorkerB.com
    Nov 2015
    43
    thanks Brian , i will, some progress today - most pieces cutAttachment 330224
    Nov 2015
    43
Name:	cnc build ply aug 2016 012.jpg
ID:	330226Click image for larger version.
Name:	cnc build ply aug 2016 009.jpg
    Nov 2015
    43
    sanding and drilling next
    Apr 2005
    253
    Its handy the you can cut the new parts on the old. May I suggest investigating the cost of support rails linear bearings as these are getting cheaper, of course everything is relative to your budget. Good luck with your build
    I'll get it finished sometime after I start it.....
    Nov 2015
    43
    thanks robe,
    Nov 2015
    43
    Nov 2015
    43
    have dismantled old machine and starting to get metal bits for rails, welding skills sorely lacking........Attachment 330804
    Nov 2015
    43
    Nov 2015
    43
    Nov 2015
    43
    who ho - got machine working, small manual test cut, all good so far
    Nov 2015
    43
    enclosure plansClick image for larger version.
    Nov 2015
    43
    frame with staggered studs to weave insulation betweenClick image for larger version.
Name:	enclosure frame.jpg
Page 1 of 2 12
  1. First MDF/plywood CNC
    By Kazik_Wichura in forum DIY CNC Router Table Machines
    Last Post: 06-11-2012, 10:29 AM
  2. MDF vs Plywood
    By Lurkepus in forum Commercial CNC Wood Routers
    Last Post: 10-08-2008, 12:19 PM
  3. best plywood
    By beamer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-06-2007, 11:27 PM
