586,103 active members*
3,232 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > MX4660 smoked driver after none moving estop...
    Jan 2008
    19
    I just smoked my second driver last night. This is AFTER installing the recommended shunt regulator... I caulked the first one up as my fault as I didn't know about the shunt regulator so purchased a new driver. This time, not so much.
    The same thing happened as the first time. The machine was NOT moving, I hit the estop and it shorts out, then the power supply does not power up.
    How should I go about getting a replacement board, and at this point I feel sending two out would be justified. Also, I feel like a wasted 100$ on this shunt regulator that doesn't seem to help....
    thank you
    landon
    Jan 2007
    235
    Where did you get the shunt regulator? Try calling leadahine.
  1. MX4660 kit
    By Bryan Rocker in forum Leadshine
    Last Post: 07-20-2015, 03:55 PM
  2. Replies: 14
    Last Post: 05-04-2015, 02:21 PM
  3. Moving Sheline driver electronics from PC to enclosure
    By dickinfr@nbnet. in forum Benchtop Machines
    Last Post: 02-19-2012, 03:42 AM
  4. Probotix 3-Axis Kit, help I smoked my driver board
    By HaroBlack in forum DIY CNC Router Table Machines
    Last Post: 08-24-2009, 04:50 PM
  5. Smoked Xylotex XS-3525/8S Driver.
    By A. Shuford in forum CNC Machine Related Electronics
    Last Post: 09-07-2004, 12:26 AM
