586,728 active members*
3,108 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Jan 2006
    11
    Notepad G code?
    I have been manually inputting my g code programs on my Fanuc OT control now for about 8 months and I was wondering if there was a way I can use something as simple as notepad or wordpad to write the programs in and then transfer them to the machine? I have a cable with a usb serial adapter one end and the relevant fanuc connection the other.
    I just dont know how to transfer the stuff any help greatly appreciated
    Francis
    FVF Custom Drums
    www.fvfdrums.co.uk
    24223
    This question has come up many times before, you need to look in the appropriate forum http://www.cnczone.com/forums/forumdisplay.php?f=70
    You can use wordpad etc, as long as the file is in TXT or ascii format, I would use a three wire cable from the serial adaptor to the Fanuc.
    You need however a modem or communication program, there are several available, Dan Fritz has one or you can go to the Cadem site and check all the parameters you need to set.
    Al.
    Albert E.
    Oct 2004
    742
    Quote Originally Posted by disinformation View Post
    Francis
    FVF Custom Drums
    www.fvfdrums.co.uk
    I use Notepad and Wordpad to create and edit all my g-code which runs under TurboCNC 4.0.
    The above programs are just text editors and should work fine for creating the g-code.
    As for transfering the files to the machine..... I cannot help you there.
    Jerry
    Nov 2003
    98
    We have used a shareware program called cnccomm for a few years. Easy to use, easy to set up.
    I will pm info to you.
    Bob
    Jan 2006
    4396
    Francis
    FVF Custom Drums
    www.fvfdrums.co.uk
    Here is a Good Software written by Dan Fritz here on CNC Zone.
    http://www.sub-soft.com/dncplus.htm
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Feb 2007
    12
    Francis,
    Actually, you can use the hyperterminal program that comes with Windows to send and receive programs. It's primitive, but it does work.
    Dec 2005
    390
    In another thread people have been talking about NCPlot for editing gcode. Cool thing is you can see the toolpaths drawn next to the gcode you are entering. It seems to have serial communication ability. They have an intro price going until March. Looks like pretty good software.
    http://www.ncplot.com/
    Jan 2006
    4396
    Quote Originally Posted by wildcat View Post
    The intro price is $75.00. I just got my first one. It has DNC Capabilities.
    Cheers!!!
    Toby D.
    Schwarzwald
    Jul 2004
    173
    Editor
    You can also use the Predator CNC Editor Lite to create, edit, print and save Gcode. The cost is nothing and is the same Editor that is included inside of Virtual Gibbs.
    Go to our website and click on "SPECIALS" to get the license info and software.
    If you want communications, you can upgrade to the Xpress Version for $250.00 and get many more features.
    Greg Mercurio
    Shop Floor Automations
    Jan 2006
    4396
    Quote Originally Posted by gm3211 View Post
    Greg Mercurio
    Did you say FREE!!!!!!! I'll have to check that out. Thanks!!!!
    Toby D.
    Schwarzwald
    Feb 2007
    15
    I use notepad on all hand written programs and EZ link software to communicate to Fanuc simlpe and free if ya want it to try toby give me a pm and I'll send it to you.
    Just another chip in the pile.
    aaron
    Jan 2006
    4396
    Quote Originally Posted by notallhere View Post
    Thanks for the offer but I have 3 at the moment. BobCAD, NC Plot, and and Old DOS EDI. Between the three there is never a problem. Maybe you can post this for other CNC Programmers that want a Free Communications Software.
    BTW: welcome to CNC Zone!!!
    Toby D.
    Schwarzwald
    Feb 2007
    15
    Im sure there is somewere i can post this but not sure were to put it it is a small file but dont want to post if it is not the place for it so let me know Toby if there is somewere i can upload it here.
    Thanks for the welcome
    aaron
    Nov 2006
    262
    I have used Norton commander on older computers that ran DOS and win3.11. There is a freeware analog called "Midnight Commander" that runs in DOS and I bet windows now, all they are fancied up DOS shells.
    One nice thing about them is many can be setup to PRINT to a serial port(configuire for an ascii printer), which you can hook to your cnc, so you can open a file,look at it, and edit it, then hit a function key and pump it into the cnc. If you do most writing and edit on the PC you will actually have very little need to ever pull a program back OUT of the cnc, it is faster to just do the edit on the PC and pump the program in again for most things IMHO.
    Bill
    Mar 2005
    1498
    070219-1805 EST USA
    disinformation:
    There are many USB to RS232 adapters that will not work sucessfully for CNC communication. The primary problem is probably in their software drivers.
    Why are so many people that are likely to use RS232 communication buying computers without an hardware RS232 port? If you have desktop you can probably install an RS232 board. There apparently are still some laptops available with hardware RS232.
    When I text edit under Windows I tend to use Wordpad. Using Wordpad you probably want to save files as Text Document - MS DOS Format .
    Apr 2006
    3206
    One Caveat.....I used Wordpad and got into trouble, seems there are some hidden characters that show up in the file that some controllers don't like. So be careful when first using any ole text editor until you're sure your control will eat what you feed it.
    It doesn't seem to happen with Notepad.
    Mar 2005
    1498
    070219-2053 EST USA
    I believe that under Wordpad when you save as MS DOS Format that all formating functions are removed. I have processed several hundred thousand byte files with no problems.
    If I am really editing a file to any extent I use Xywrite under DOS from the early 1980s. It is for the most part easier to work with.
    Jan 2006
    4396
    Quote Originally Posted by fizzissist View Post
    When using WordPad you need to save as a TEXT (*.txt) file or you get the weird charactors. Saving as txt removes those so the machine control will eat everything you feed it. I like WordPad because it has better editing options like "Find and Change to" and quick Icons too.
    Cheers!!!!:cheers:
    Toby D.
    Schwarzwald
    Apr 2006
    3206
    Quote Originally Posted by tobyaxis View Post
    AHHA!!!
    That explains why everytime I saved a file as *.html I got a smiley face engraved next to every hole!!!
    (btw, it was on an AHHA retrofit I built that I learned about imbedded characters!!)
    Jan 2006
    4396
    AHHA!!!
    I have a DOS Editor called EDI from G-Zero by Rapid Output. That is the G-Code Editor that got me interested in CAD/CAM. It actually shows those hidden Charactors in the Text. It is very interesting to see these. Some of them can't even be replicated with your keyboard LOL
    I'll open the dusty old Lap Top and show a screen shot later. Its Weird Stuff
    Toby D.
    Schwarzwald
Page 1 of 2 12
  1. To hand Code? or to CAD Code?
    By automizer in forum Polls
    Last Post: 07-22-2015, 09:58 PM
  2. Wierd NC Code and G-Code
    By Tazzer in forum Uncategorised CAM Discussion
    Last Post: 01-09-2012, 08:07 PM
  3. learning g code or cad-cam code output?
    By slow_rider in forum G-Code Programing
    Last Post: 02-28-2010, 03:48 AM
  4. G-code for beginners - want to learn G-code
    By FPV_GTp in forum G-Code Programing
    Last Post: 11-18-2008, 06:25 AM
