586,105 active members*
3,215 visitors online*
    Apr 2016
    Question Help with feeds and speeds
    Hi, very very noob on the cnc world talking:
    I've build myself a cnc to play with and after some tunnig and test cuts i've gonne for a bigger project.
    I'm using this bit 5pcs Extra Long 3mm 2 Flute HSS Aluminium Extended End Mill Cutter CNC Bit Kit | eBay and cutting some kind of plywood. With the zero experience i have, i'm using the feeds and speeds from easel, with a small difference.
    Feed: 800mm/min
    Plunge: 300 mm/minDepth per pass: 0.8 mm/min
    My spindle is Makita 3709, which only have one speed of 30.000 RPM.
    Problem:
    20 min after i started the milling, i start smelling burning wood ... 5 min later the bit was all black and the chipload was on fire. The chiload was not really chipload was more like a dust.
    What am i doing wrong ? How can i adapt feed and speed to different materials or bits ?
    I looked all over but the feeds and speeds that i see are all 3,9999 mm of depth, and that my machine can't handle.
    Hope you cnc'ers can help me.
    Thank you
    Apr 2015
    113
    Re: Help with feeds and speeds
    you are going WAY too fast on the spindle. I cut at 16k at 3-4000mm/min with a two flute!!
    Luthier/Woodworker/Machinist in NS, Canada.
  1. Speeds and feeds
    By SMW81 in forum MetalWork Discussion
    Last Post: 08-04-2014, 10:39 PM
  2. Speeds/Feeds ... for a nub
    By thomax00 in forum MetalWork Discussion
    Last Post: 04-16-2013, 07:43 PM
  3. Feeds and Speeds again...
    By zaebis in forum Syil Products
    Last Post: 08-07-2009, 07:07 PM
  4. Feeds and Speeds
    By sjotime! in forum Mach Software (ArtSoft software)
    Last Post: 02-17-2008, 10:46 PM
  5. Speeds and Feeds
    By CLP CORP. in forum WoodWorking Topics
    Last Post: 12-07-2007, 07:38 PM
