603,942 active members*
2,837 visitors online*
Results 1 to 6 of 6
    Feb 2007
    newbee question
    I am trying to build a cnc mill. I have a Mechatronic Driver board and Lin stepper motors. I have it all hooked up and trying to test motors, I using Kcam and notice when I move the motors manually the motors move but I notice a thump about every revolution of the motor. Is this normal or is something set wrong?
    Aug 2005
    86
    ...my setup does that too, have you tried to get it to work with Mach? I have yet to get in working with Mach.
    Jun 2007
    10
    Has anyone found out what could be a solution to the problem because I'm experiencing the same phenomena?
    Aug 2005
    86
    ...the thumb went away once I mounted them on the mill. The load from the table smoothed out the motors.
    Jun 2007
    10
    Smile
    I've done some more testing and I think I've found the cause for the mysterious thump (at least in my case). I'm running KCAM on an older laptop (~400 Mhz) and each time the plot was updated, motors would get stalled for a moment. When I disabled position update in the settings the thump was gone and motors are now running much smoother.
    Jun 2007
    10
    Smile
    Edit: Can a moderator please delete this post?
  1. Newbee Fanuc OT Mod A Questions
    By bigsteve in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-26-2006, 05:17 AM
  2. help the newbee understand software
    By runswithscissor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-08-2006, 01:07 PM
  3. help a newbee, trying to build a cnc torch table
    By jim fuchs in forum Servo Motors / Drives
    Last Post: 01-18-2006, 08:45 AM
  4. Another newbee needs help chooising motors
    By P-4 in forum Stepper Motors / Drives
    Last Post: 06-23-2005, 06:27 AM
  5. few newbee questions
    By njtermite in forum Material Machining Solutions
    Last Post: 02-19-2004, 11:55 PM
