603,365 active members*
3,260 visitors online*
    Aug 2003
    94
    Newbie question on drill bits
    Hello all,
    I did some search one ENCO, but i don't know which kind of drill bits will work on aluminum. I brought a drill bit earlier, but i didn't know it was for drilling ground or wall.
    Please help me to find the drill bits.
    Size:
    1.25"
    .75"
    .25"
    thank you
    Apr 2003
    1873
    Aluminum is pretty forgiving when drilling, most any HSS (high Speed Steel) drill bit will work fine, either 118 or 135 degree, split point is standard now days. Be frequent in bringing the bit out of the hole to remove the cuttings. I would stay away from reduced shank if at all possible.
    What equipment are you using to drill with?
    1.250 is quite a drill and would be quite expensive, you may find it easier to drill say 3/4" then bore it on a mill.
    Ken
    Aug 2003
    94
    i'm using drill press.
    Nov 2003
    299
    If your drilling deep holes into alum. the chips will have a tendency to "stick" to the bit and not come out of the hole, therfore plugging the bit. This can be reduced with some lubricant while drilling. Also, Tin coated bits may help with drilling alum.
    I ALWAYS use a coolant when drilling steel or other hard metals. Although it's messy, your drill bits will last ALOT longer.
    Aug 2003
    94
    thanks for the tip
  1. Newbie question: how do I machine this? (Drawing attached)
    By Aegeon in forum MetalWork Discussion
    Last Post: 12-04-2005, 08:20 PM
  2. Bridgeport mill newbie question...
    By GalaticDan in forum Bridgeport / Hardinge Mills
    Last Post: 06-06-2005, 08:02 AM
  3. Stop Bits, Parity
    By gar in forum Computers / Desktops / Networking
    Last Post: 06-04-2005, 08:10 PM
  4. What type of drill bits for lathe?
    By James04 in forum DNC Problems and Solutions
    Last Post: 05-19-2003, 07:37 PM
  5. What type of drill bits for lathe?
    By James04 in forum Uncategorised MetalWorking Machines
    Last Post: 05-10-2003, 06:59 PM
