586,357 active members*
3,843 visitors online*
    Sep 2016
    7
    bubbles in tube everytime I turn on watercooler
    I just recived my first chineese lasercutter 150W.
    I have got rid of all the bubbles in the tube. But each time I turn on the water cooler there are more bubbles.
    Im using destilled water.
    How can I make the system bubble free ?
    Best regards
    Edvin
    Apr 2013
    10
    Re: bubbles in tube everytime I turn on watercooler
    Personally I let my pump circulate the water for a few minutes before I start cutting and leave it running until the water has cooled to room temperature afterwards
    Oct 2015
    96
    I have just water tank at this moment (not cooler) and serious water bubbles appears ONLY when outlet of laser water is NOT submerged i tank. after start water pump it's does not matter.
    Polish @ Éire
    Feb 2009
    6028
    Not sure if it applies to the larger tube like that, but I had to turn my tube so the inlet and outlet face up, that way the pump forces the air out immediately.
    Sent from my A3-A20FHD using Tapatalk
  1. Bubbles in Mixture of Epoxy Resin
    By Saimon in forum Epoxy Granite
    Last Post: 05-02-2015, 09:09 AM
  2. Laser beam turn around inside tube
    By DV0001 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-20-2015, 09:47 PM
  3. Machinable wax full of bubbles!
    By littleCNCjohn in forum Glass, Plastic and Stone
    Last Post: 03-04-2014, 10:47 PM
  4. small bubbles in laser tube, problem?
    By fdm_guy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-06-2013, 09:39 AM
  5. acrylic glue leaves tinny bubbles
    By bbbobbb in forum Material Machining Solutions
    Last Post: 05-26-2010, 02:19 PM
