Hi guys,
May anyone help me with the matter below?
I got a machine that show problem in moviment. Sometimes it jumps, crossing the machine then the parts cut got with dimension error.
The machine is gantry with master and slave motor. It looks like that the slave run ahead the slave. I decreased the following error and I could see that the machine when crossing the error is showed at the CNC screen.
I changed the signals cable, using today STP cables. I separeted the signals cable from torch cable.I avoided use conector between Driver / CNC and Driver/motor. I connected them directly.
The signals cable gotta a 30m of length. I suppose that this cable is captionned the HF from plasma machine and causing some error in encoder counting. I would like to get suggestion to solve this problem and avoid the HF get in the driver the CNC.
The machine is a gantry machine, with slave and master.
The CNC is Edge II from Hypertherm Automation.
The plasma is from Hypertherm as well, model HPR 260.
Any question else, please tell me.
Thanks for all
