603,855 active members*
3,536 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 1095 steel stock bowing after facing .25mm
    Jul 2016
    18
    As the title says. I am working with 2" x 10" x 5/32" 1095 steel, the stock is very flat before beginning work. However, after the first side had 0.25mm faced off, I noticed a severe curve, as the stock now bowed in the middle. This stock is small enough that I can use a rubber mallet to flatten the stock on top of a flat surface, and returns it to a flat(ish) state. However, I wanted to know what I could be doing to prevent this from happening in the first place.
    I am using aluminum soft jaws on my vise to hold the stock down, and I'm using the Tormach SuperFly Cutter for my facing.
    Thanks!
    Aug 2015
    108
    Re: 1095 steel stock bowing after facing .25mm
    Its probably the mill skin on the material.
    Make sure there is enough material to be able to take skim cuts and still finish the part.
    Load it in the vise and DO NOT hammer it down. Let it clamp in the vise in its natural state. Take a 0.1 to 0.2mm skim cut off the top.
    Flip the part over in the vise and do the same thing for the bottom, also DO NOT hammer it down.
    Flip the part again and start from this side did the first skim cut and you should be able to machine the part without it warping further.
    Hammering a warped part into the vise causes it to hold the warping once the part is unclamped. Generally depending on how the material was made cold or hot rolled, there is stress in the outside skin of the part. Once you remove the skin it causes the material to pull in different direction.
    Good luck!
  1. 1095 steel
    By Brian FRF in forum RFQ (Request for Quote)
    Last Post: 10-17-2015, 07:33 AM
  2. Fixturing large stock for facing?
    By cordvision in forum Tormach Personal CNC Mill
    Last Post: 03-31-2015, 02:15 AM
  3. Watch hands froms 0.25mm - 0.3mm mild steel
    By Kalvin in forum RFQ (Request for Quote)
    Last Post: 10-19-2012, 05:23 PM
  4. fast stock removal on steel
    By dynamotive in forum MetalWork Discussion
    Last Post: 02-02-2007, 04:02 AM
  5. Facing aluminum stock- tool to use
    By leberen in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2006, 04:02 PM
