586,096 active members*
3,397 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Mach3 and Profilli 2 Software Trubbles
    Oct 2016
    Ok Here it goes I am rather new at this CNC stuff so I will try to be as detailed as i can,
    I am using Profili2 to create my wing panels for foam RC Planes. I go through all the process on the right side wing panel. Export into a file that Mach3 can read. Load it on Mach3 run the cnc and cuts the wing perfect. OK now hears the kicker in profili2 at the end of the process there is a box you can click so it makes a mirror of the first panel hence right and left wings. Now when I click this box and run it on the cnc it starts off good about 1/2 through the cut one side does not continue to fallow the correct path and will continue till it goes to the Estop position. Fr the life of me I cant figure what is going on. Any help would be great.
    And thanks in advance.
    I am also including the 2 files
    Help.nc - is the one that cuts good
    Help2.nc is the one that does not cut right
    khowlette Guest
    Re: Mach3 and Profilli 2 Software Trubbles
    Hi
    A bit late on this post but did you ever get this sorted. Not sure if you may have contacted me via my website RC Planes - Hot Wire CNC Foam Cutter, CNC Router and 3d printing - rcKeith I do quite a lot of hot wire cnc stuff over there and have several videos and an eBook
    Keith
  1. HELP with MACH3 software
    By PaulGB in forum Avid CNC
    Last Post: 04-28-2016, 05:05 PM
  2. new to Mach3 but not cad/cam software
    By FUBAR62172 in forum Mach Mill
    Last Post: 02-13-2016, 03:01 AM
  3. Cam Software for Mach3?
    By eliteaquatics in forum Mach Software (ArtSoft software)
    Last Post: 10-20-2013, 02:35 AM
  4. CNC Hot Wire, MACH3 & Profilli
    By sharbold in forum CNC Wire Foam Cutter Machines
    Last Post: 05-26-2012, 11:45 PM
  5. Mach3 software
    By A Craddock in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-02-2011, 07:46 PM
