586,111 active members*
3,525 visitors online*
    Feb 2004
    466
    Hard Disk stepper
    Hi.
    I want to do some testing with salvaged stepper from a harddisk (samsung) wich has 4 wires. But I thought that 4 wire are bipolar steppers and those have 2 coils wich do not cross leads.
    This stepper has the wires labeled as A, B, C and CT and Ive tested them with a digital ohm meter and get :
    A-B : 4 Ohm
    A-C : 4 Ohm
    A-CT : 2 Ohm
    B-C : 4 Ohm
    B-CT : 2 Ohm
    C-CT : 2 Ohm
    Is this right for a bipolar stepper?
    Any coments on this motor?
    Feb 2004
    466
    Will this be a variable reluctance four windings motor?
    Feb 2004
    466
    Actualy it looks like a normal variable reluctance motor.
    Anyone uses those in projects?
    Feb 2004
    466
    The chip wich drives the stepper located on the HD is L6269.
    I wonder if it is possible to use the driver and hook it up to the LPT somehow.
    I am going to read the info on this L6269 on ST's http://www.st.com/stonline/books/ascii/docs/6626.htm
  1. A2100 Hard Disks
    By tricky in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2018, 08:33 AM
  2. A2100 Cincinati Hard Disks
    By tricky in forum Uncategorised MetalWorking Machines
    Last Post: 05-28-2005, 02:03 PM
  3. Not good for a stepper motor?
    By FLUTE HEAD in forum Stepper Motors / Drives
    Last Post: 12-02-2004, 06:31 AM
  4. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
  5. disassembly of stepper motors
    By dhprc2 in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 01:09 AM
