586,111 active members*
3,522 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas Vf2 with 5 axis trunion B axis zero return offset
    Jul 2014
    221
    how do you change zero position for B axis (rotary axis, not tilt axis)?
    I have a vice on the trunion which isnt aligned with X and Y, because T-slots on the rotary table aren't aligned properly, so I rotated it manually and noted the position of aligned B axis in debug mode (raw data-encoder data).
    I tried entering that value to parameter 224, but that changes A (tilt) axis zero position.
    which parameter does the same for B axis?
    thanks
    Nov 2006
    490
    Re: Haas Vf2 with 5 axis trunion B axis zero return offset
    Would it be possible to enter the "aligned" position as a work offset for the B-axis? That's what I do when aligning a workpiece onto the rotary platter (if I understand you correctly)
    Jul 2014
    221
    parameter 213 solved it.
    go to alarm screen, enter debug, go to settings, unlock parameters, go to position display, write the value down for b axis when aligned, go to parameters and 213+arrow down, enter that value, voila (if it doesnt work first time, enter same value with minus sign).
  1. Help with 5th axis trunion table.
    By classic9mm in forum Uncategorised MetalWorking Machines
    Last Post: 10-30-2016, 09:45 PM
  2. Need Help....Y and B axis won't zero return......?????
    By figurehead in forum CNC Swiss Screw Machines
    Last Post: 02-03-2015, 09:53 AM
  3. Looking for a non-trunion 5 axis vertical. Pros/cons of trunion?
    By vettespeed in forum Uncategorised MetalWorking Machines
    Last Post: 12-08-2013, 05:18 AM
  4. 5th axis help, trunion swings in both directions
    By houstonsamuel in forum Mastercam
    Last Post: 01-14-2011, 08:29 PM
  5. 5 Axis Mill (Trunion type), with Arm ATC, and Pallet changer
    By PoppaBear10 in forum Mach Software (ArtSoft software)
    Last Post: 07-14-2009, 01:49 PM
