586,069 active members*
3,703 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Centurion V control says "insert diskette into A drive on boot up
    Dec 2005
    134
    Hi All,
    I just purchased a used bed mill with a Centurion V control. When I first turned the machine on the control asked which set up we wanted. I pressed "1" for standard. Then the screen went blank. I waited for a while and nothing happened so I turned the power back up and now on boot up it is asking for us to insert diskette into drive "A". There were two disks with the machine and one of them says parameters so I tried inserting that but it just keeps giving me an error that the "drive is not ready press any key". Any suggestions? Thanks. Joe
    Mar 2014
    55
    Re: Centurion V control says "insert diskette into A drive on boot up
    Could be a bad battery.
    Checkout this thread http://www.cnczone.com/forums/showth...0624-Centurion V won't boot up
    Dec 2005
    134
    Thanks tlowe - where do I find this and what does it look like? We will get started with those checks.
    Jul 2010
    548
    Hi Joe, at the menu select F2 ( setup SRAM) press Y ( yes) for all questions.
    when it asks to insert a disk just press enter. ( the disk is an internal electronic disk,, B
    when it is done it will ask to "format" another select N (no)
    Them press ESC to reboot the machine.
    This will load a set of default parameters.
    you would then load "YOUR" parameters F7 (prams) F7(load)
    then cycle the power on the machine.
    If the simdisk battery is "dead" it might kick you back to the shell menu.
    I stock these batteries.
    sportybob
  1. Centurion V won't boot up
    By DEAN-O in forum Milltronics
    Last Post: 08-14-2020, 02:08 AM
  2. Centurion 4 "error 02 fault detected"
    By Brian FRF in forum Milltronics
    Last Post: 10-17-2014, 10:24 PM
  3. diskette drive
    By stevieboy in forum HURCO
    Last Post: 12-29-2011, 08:55 PM
  4. What insert can I use to make a small radius (0.004"-0.007") on a part
    By Liberty02 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 08-16-2011, 03:58 PM
  5. Replies: 2
    Last Post: 02-04-2010, 01:28 AM
