603,795 active members*
2,915 visitors online*
Thread: m100/101
    Dec 2016
    m100/101
    hi all have recently purchased a new cnc plasma table but having issues . the plasma will cut for about a minute torch head comes down senses the material goes to cut but doesn't fire . then I get an error saying the current m100/101 command has timed out . anyone have any ideas. getting no help from the supplier. many thanks people
    Jul 2005
    2415
    Re: m100/101
    Well, some information about the controller software and the CAM program would be of great help. Most M codes above 99 are not inherent to a controller (there are some exceptions) If its MACH3 then all of the M (macros) are in a file in the Mach3/macros/[your profile name]/ and are individual scripts named the same as the macor number.
    Someone has either written the macros and you need to figure out what its trying to do, OR they are part of the engine (base macros) and you need the documentation for that specific controller. Its unfortunate you cannot get support from the vendor after you gave them your money.
  1. M100 and above, don't work??
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-19-2014, 06:56 PM
  2. 078 NUMBER NOT FOUND with M100 ON FANUC 18M
    By dung_ninhbinh in forum Fanuc
    Last Post: 09-06-2010, 03:21 AM
