603,963 active members*
2,482 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > PMDX-107 + PMDX-126 + ESS connected to Huanyang HY02D223B -Newb pulling hair out
    Sep 2009
    4
    Please bear with me.... bit of a newb when it comes to all this... I have a PMDX-107 + PMDX-126 + ESS connected to Huanyang HY02D223B.
    The test button on PMDX-107 starts the spindle turning and gives me 10.5v on 1st press and 3.47 on 2nd(on pins 1->2.) The VFD/Spindle goes to 400(max speed) regardless of voltage.
    Can someone put me on the right path??? I don't mind reading but cant seem to find a good primer or anything related to my specific issue.
    Thanks!
    After reading what others have done I setup everything as follows:
    PMDX-107 to VFD
    Pin 6 - Rev/Dir - REV
    Pin 5 - Fwd/Run - FOR
    Pin 4 - COM - DCM
    Pin 3 - Not used
    Pin 2 - Aout - VI
    Pin 1 - Agnd - ACM
    PMDX-107 Config settings (dip switches)
    Config 1 = Off (Normal Mode)
    Config 2 = Off (Normal Mode)
    Config 3 = Off
    Config 4 = Off (charge pump signal required)
    Slow = Off
    5v/10v = Off (10v reference)
    PMDX-126 Settings
    Config 1 = Open
    Config 2 = Closed
    Config 3 = Closed
    Config 4 = Closed
    Config 5 = Closed
    Config 6 = Closed
    Config 7 = Closed
    Config 8 = Closed
    Changed PD001 Source of Run Commands to '1'
    If PD002 is set to 0 unit runs at 400, if set to 1 it goes to minimum (119.9)
    Changed PD005 Max operating frequency to 400hz
    Changed PD004 base frequency to 400hz
    Changed PD003 Main frequency to 400hz
    Changed PD006 Intermediate frequency to 2.5
    Changed PD008 max voltage to 220v
    Changed PD009 Intermediate voltage to 15v
    Changed PD010 Min voltage to 8
    Changed PD011 frequency lower limit to >119.9hz (so I can see when it is just delivering Minimum)
    Changed PD142 rated motor current to 11
    Sep 2009
    4
    Re: PMDX-107 + PMDX-126 + ESS connected to Huanyang HY02D223B -Newb pulling hair out
    Posting for posterity. The answer was provided by another user in another forum...
    PD072 Higher Analog Frequency - Needed to be set to 400 and WAS on the default of 50.
  1. PMDX-107 and Huanyang SL-240EE VFD
    By toddedwards in forum Spindles / VFD
    Last Post: 12-09-2014, 05:17 AM
  2. Replies: 0
    Last Post: 02-26-2014, 03:41 AM
  3. Having Issues w/ PMDX-126 PMDX-134 and Ethernet Smooth Stepper
    By Hurshy in forum Community Club House
    Last Post: 08-27-2013, 01:20 PM
  4. PMDX 107 to Huanyang - refusing to work
    By jestah in forum DIY CNC Router Table Machines
    Last Post: 02-07-2011, 03:24 AM
  5. PMDX-125 or PMDX-132 for Geckos?
    By Nivea in forum Gecko Drives
    Last Post: 03-24-2010, 08:18 AM
