586,089 active members*
3,820 visitors online*
    Dec 2016
    7
    Anodizing quality issue
    Hi I recently got a 6061 part that was just machined and bead blasted by another company (very good quality)to be re-bead blasted and anodized. I got them to re blast the part and anodize type 2. Prior the finish was great but it wasn't anodized, now that it's anodized it has patches on it. (They look like news paper texture, or water stains and not uniform dots like prior to bead blast) What reasons would the patches come in, and is it possible to get it fixed? I attached a photo.
    Thx
    prof quack
    15362
    Re: Anodizing quality issue
    Quote Originally Posted by professorquack View Post
    Thx
    prof quack
    Bead Blasting can cause that to the Finish, and also the anodizing process, Bead Blasting is a bad idea, unless you have clean uncontaminated Beads, just for doing aluminum, and you get a perfect uniform finish, which is hard to do, water bead blasting is the best, as it takes away the oxides and leaves a clean surface
    To fix it, it would have to be stripped, and try to reblast it, or have the anodizer etch it
    Mactec54
    Dec 2016
    7
    Thx for the quick reply, I saw the prior bead blast result ((from original machinist) and it was pristine except for a minor smudge so the anodizer company said they should reblast it. I didn't see their blast job before they anodized it so I don't know the quality. Will stripping and redoing it make things worse? (Possibly I mean) these are one off prototypes and were a penny so I'd want to minimize the damage.
  1. Home Anodizing. Low Current Anodizing. 720 Rule
    By kreutz in forum Mass finishing equipment/media/strategies
    Last Post: 11-29-2019, 04:13 PM
  2. Hpr 260 edge quality issue
    By PR92 in forum Hypertherm Plasma
    Last Post: 05-31-2015, 05:05 AM
  3. Quality Engineer/Quality manager - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:51 PM
  4. Anodizing?
    By Klox in forum MetalWork Discussion
    Last Post: 05-03-2005, 06:46 PM
