586,075 active members*
4,303 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > how to shut off Fapt on a 1999 daewoo with FANUC Puma 200 with FANUC 18T control
Results 1 to 13 of 13
    Oct 2016
    14
    as lona as Fapt is we can not use canned cycles but do not know how to turn off FAPT please help
    G70-G76 won't run with FAPT
    Oct 2016
    14
    Re: how to shut off Fapt on a 1999 daewoo with FANUC Puma 200 with FANUC 18T control
    as long as Fapt is ac
    tive we can not use canned cycles but do not know how to turn off FAPT
    Oct 2016
    14
    can cycles won't run i.e. g70-76 we think it is a FAPT conflict ? need to disable FAPT ? on Fanuc 18T on a deawoo Puma 200 how do you do?
    Oct 2016
    14
    how do you turn off or deactivate FAPT on 1999 Daewoo Puma 200 with Fanuc T18 contol please help Can cycles won't run with FAPT activated
    Apr 2009
    1379
    You may have to change the operating system. Depending on the exact control model (a,b,c or i), that may be fairly simple and inexpensive.
    Give the model info.
    Oct 2016
    14
    Thank you for your help the Model # 200LC Serial # PM200837
    Apr 2009
    1379
    I meant the control model; take some close-up photos of the control part numbers.
    Oct 2016
    14
    Oct 2016
    14
    Type A20B-0222-C071/TBR
    No. N00553
    Tatung Model CD14BS
    s/n 73310218
    May 2009
    106
    It is possible to deactivate fapt.
    But software has to change.
    And fanuc alphanumeric keypad as the addressing of keys are different.
    Like for example the letter p might be g ore some such.
    In the 90s I installed quite a few of these options on Daewoo lathes.
    I might even have some notes on it.
    I remember that the keypad had to be changed,an extra rom module and possibly some option bits.
    Apr 2009
    1379
    The photos are not from the control. Which control model is it? Is it a 18C?
    Oct 2016
    14
    How do we change operating system? were would be get it?
    Apr 2009
    1379
    Unless the control is older then a 18B, the software is on flash and can be changed through a known procedure.
  1. Replies: 9
    Last Post: 05-16-2016, 07:31 PM
  2. Replies: 0
    Last Post: 03-18-2016, 10:55 PM
  3. Daewoo Puma 4-3A w/ Fanuc 0T
    By ProfSS in forum Fanuc
    Last Post: 11-19-2012, 07:01 PM
  4. DAEWOO PUMA 10 W/FANUC 3-T
    By wes4540 in forum Daewoo/Doosan
    Last Post: 04-28-2009, 05:56 PM
  5. Daewoo puma 12-l fanuc 0-T-A control
    By smts in forum Daewoo/Doosan
    Last Post: 03-29-2008, 02:27 AM
