586,103 active members*
3,672 visitors online*
IndustryArena Forum > CAD Software > Solidworks > ADJUSTING FOR PLATING ALLOWANCES IN SOLID WORKS
    Sep 2016
    4
    Hi ,
    Is there any software or calculator that can automatically compensate for plating allowances so I can output a pre plate print ?
    Thanks in advance.
    Scott
    Mar 2008
    683
    Re: ADJUSTING FOR PLATING ALLOWANCES IN SOLID WORKS
    If you get lucky and the geometry cooperates you can add a INSERT -> FACE-> OFFSET-> Select all surfaces and check which side for the offset. Set up a configuration for this command and refer to that configuration in your drawings
    Apr 2015
    113
    Use a formula. For your thickness, do (X) + Plate, where "plate" is defined as a value in your functions sheet.
    Luthier/Woodworker/Machinist in NS, Canada.
  1. negative of a solid in solid works
    By ringanator in forum Solidworks
    Last Post: 02-09-2015, 03:58 PM
  2. Solid works to DXF
    By Rik H in forum Solidworks
    Last Post: 06-06-2013, 02:57 PM
  3. Replies: 0
    Last Post: 05-01-2013, 05:00 PM
  4. need help with Solid works
    By redbaby48 in forum Want To Buy...Need help!
    Last Post: 11-07-2011, 07:15 PM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
