586,080 active members*
3,729 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Laminating your air stream for more powerful chip clearing
Results 1 to 8 of 8
    Jan 2013
    263
    Has anyone tried using many tubes in parallel to produce a more directed air stream? This is a common practice when producing a laminar water stream (i.e. waterjet cutting and the bellagio fountain) but I can't find info on it being used for air.
    I've got $40 worth of syringe tubing on my counter which I'll use to try it out. It's going to be a real pain cutting and deburring them all though.
    May 2013
    480
    Re: Laminating your air stream for more powerful chip clearing
    water isn't compressible....
    Jan 2013
    263
    Quote Originally Posted by Eldon_Joh View Post
    Thank you for sharing that seldom-known tidbit. Obviously there are differences between air and water (and more importantly, water projected into air vs. air projected into air), else there'd be no need for the question in the first place. There must be some natural conclusion that we're meant to draw from your statement, but it certainly can't be "ergo there's no benefit to doing anything with your air stream other than spitting it out of a hole and hoping for the best" because it's already well established that using a long straight tube produces a longer-reaching and more directed air stream (due to lower turbulence, I believe) than merely using a nipple.
    Jun 2010
    4256
    Would you have a proper engineering reference for that? One which actually quantifies the effect.
    I use a simple LineLoc nozzle.
    Cheers
    Roger
    Jan 2013
    263
    I'm no expert in fluid dynamics. I just know that laminar airflow is a thing i.e. laminar flow hoods https://en.wikipedia.org/wiki/Laminar_flow_cabinet
    "Well-established" may have been pushing it, but through highly scientific studies in my garage where I've used the $20 air compressor accessory kit to blow air 2 inches into my hand with various nozzles, it sure seems to be the case. I admit, I could be wrong.
    Jun 2010
    4256
    Ah - two very different things here. A laminar flow system is at a slow speed, well below the onset of turbulance. But a jet of compressed air is usually well above the onset, and the behaviour is very different.
    But if what you have made works for you, fine.
    Cheers
    Roger
    Dec 2013
    5717
    I think this is what you are trying to do
    How Do Air Amplifiers Work
    Jan 2013
    263
    OK, I see more now why people (I'm looking at you, Eldon_Joh ) would think this is an unachievable goal - since the air will expand immediately after exiting my tubes, the amount of turbulence prior to that is of little consequence.
    I might have to find a different use for the $40 worth of syringe tube, preferably without breaking bad.
    I'll check out the air amplifier in more detail. Hard to tell from a glance if it's different from a venturi nozzle, which I haven't been very impressed with for the purpose of directed air flow. But then again, this was from the $20 accessory kit.
  1. ABS chip clearing
    By Ty G in forum Glass, Plastic and Stone
    Last Post: 09-04-2014, 09:14 AM
  2. What chip(s) do I need for binary to pulse stream conversion ?
    By greybeard in forum CNC Machine Related Electronics
    Last Post: 11-21-2013, 09:49 PM
  3. Replies: 4
    Last Post: 12-03-2011, 01:16 AM
  4. Laminating Birch
    By Drools in forum Musical Instrument Design and Construction
    Last Post: 11-02-2011, 03:22 PM
  5. laminating MDF
    By Drools in forum Commercial CNC Wood Routers
    Last Post: 08-30-2010, 05:05 PM
