586,106 active members*
2,975 visitors online*
    Dec 2016
    12
    RICHAUTO A11E - No USB?
    Hi Everyone
    I recently purchased an cnc router that is controlled by a RICHAUTO-AUTONOW-A11E controller.
    The problem i have is that it will not recognise and usb sticks or the computer. When i try to read the USB stick is just states "There is no item in this directory." I also can't work out how to get the controller to plug & play to the computer.
    I have tried
    15+ USB sticks
    safe removing usb sticks
    Several different .tap & .nc file formats.
    3 different usb leads to the computer.
    clearing currently saved files.
    powering up the unit with usb in already
    powering up and then plugging in the usb
    reading the 60 page chinglish manual over & over thinking i missed something.
    different usb ports
    different computer
    I am not getting and lights on the USB stick so i am not sure if the controller is faulty or whats going on.
    I'm also not sure if i am even trying to access the files correctly as the manual is so bad.
    Can anyone with experience with this controller please give me some guidance.
    After sales service is no good due to Christmas / New Year holidays
    Ben
    Dec 2016
    12
    Re: RICHAUTO A11E - No USB?
    Anyone got and advice. More info needed?
    Dec 2013
    121
    I got the same model and same problem
    did you find a solution?
    Jun 2018
    362
    To see the handle via USB to PC:
    1. power it up while holding the OK and CANCEL buttons.
    2. Leave the CNC machine OFF, use item 1 and connect USB cable to handle
    If you do the above, the handle needs to be power cycled to then control the machine.
    Filenames on a USB stick work with *.NC extension. Try using the RUN/PAUSE button to access the UDISK (external USB).
    Also, go through the SETUP screens to ensure all is enabled for what you want. Note that the A11 propable needs to be to to honour G and M codes from programs otherwise it might ignore settings like "F" for speeds.
    I have this problem and it is solved by formatting the USB stick to FAT32.
  1. richauto A11 dsp control
    By senthil_kkl in forum Controller & Computer Solutions
    Last Post: 10-13-2018, 06:50 AM
  2. RichAuto controller issue
    By bonerbill in forum USA Club House
    Last Post: 09-30-2016, 07:43 AM
  3. Chinese 6090 on Richauto DSP
    By andrewdenhaan in forum Chinese Machines
    Last Post: 01-07-2016, 07:41 AM
  4. dsp Richauto A11 Visualmill rznc 0501
    By nostradamus100 in forum Chinese Machines
    Last Post: 06-04-2015, 04:41 PM
  5. Need help on RichAuto A11S Handle
    By albeagle in forum Chinese Machines
    Last Post: 03-02-2015, 06:15 PM
