586,036 active members*
4,112 visitors online*
Page 1 of 2 12
Results 1 to 20 of 38
    Aug 2005
    128
    Biesse Rover 346 retrofit
    Hi all,
    I just purchased a Biesse Rover 346 with intents of retrofitting with Linuxcnc.
    I plan on using mesa cards:
    5i25, 7i77, 7i74, 7i70 and 2X 7i71.
    I have the machine in my shop and mapping out all the I/O's.
    Waiting on connectors to connect 600V to the machine.
    See some pics below:
    Aug 2014
    232
    Re: Biesse Rover 346 retrofit
    That's a beast ! What are you planning to use it for ?
    Is the original controller broken ? Or are you having trouble getting code to drive it ?
    Aug 2005
    128
    The original controller is not broken, in fact the prior owner ran some gcode on it.
    I dont want to try or even think about operating that antequated controller. Going to take the time and retrofit it and get busy making sawdust.
    We have a wood shop with a 4x4 cnc i made to do all our stuff and we need a 4x8 cause we are turning down jobs cause we dont have the machine for it. We are a small shop of 3.
    Aug 2014
    232
    I understand about old controllers, they can be real pain.
    Good luck with your conversion, I'll be watching with interest.
    Aug 2005
    128
    I have the machine powered up and running on the old control. Everything seems to be working even the vaccuum pump.
    I have installed LinuxCNC and mounted by Mesa cards for the retrofit. The boards are powered talking to LinuxCNC and that part is working now also.
    I have to find the offsets for all the tools before I start cutting and transfering on Linuxcnc. Below are some pics.
    In the meantime my bandsaw bearings bit the duwst so I have that all apart, and I have a job today so, today will not be a fun day....
    Attached Thumbnails Attached Thumbnails IMG_1273.JPG   5v applied.jpg   IMG_1271.JPG   IMG_1274.JPG
    Aug 2005
    128
    Aug 2005
    128
    Aug 2005
    128
    Aug 2005
    128
    Figure out the startup relay logic and starting to transfer wires.
    Alot of relays. 110 relays. Good thing I can reuse the existing relays with all the wiring intact.
    Aug 2005
    128
    Most of the retrofit is done. Will post some more pics during the process and schematics when I am finished with them.
    All that is left is the Automatic Tool Changer. Everything else is working......
    Jan 2010
    20
    That looks fantastic, good job. that is exactly what I want to do. my machine is from 1996, it looks pretty much like yours. I will pm. you soon :-)
    Colin
    Feb 2008
    482
    biesse have great frames. ive converted 2 to mach3. programming the drilling in an easy to use way was the most fun!
    here is mine https://www.youtube.com/watch?v=tyAp6SNzSE0&t=14s
    so much to learn, so much to pass on.
    Jan 2010
    20
    Quote Originally Posted by battwell View Post
    That is very nice work to Battwell, maybe you can help me out with my convertion. I allready run Mach3, so I would like to convert it to a Mach3 or 4 machine as I allready know the program.
    Here is my machine.
    Colin
    Feb 2008
    482
    if i was doing another one- id convert it using uccnc software.
    i have analogue control working via a galil controller.
    uccnc has a much better and more accurate motion planner than mach3.
    i use it on my other big machines.
    couldnt do this with mach 3 in cv mode.
    https://www.youtube.com/watch?v=JJmcugyW8xM
    Jan 2010
    20
    battwell I think I will go uccnc! it looks very versatile.
    What options do I have regarding motion controller??
    Aug 2015
    21
    This is a great thread, good job on the conversion!!
    Sent from my SM-G900I using Tapatalk
    Aug 2005
    128
    I do not know the UCCNC or whatever that controller is...lol, I use Linuxcnc and it is working amazing. Took me three weeks about to convert and 1000.00 worth of hardware.
    I am cutting my first job o it tomorrow. I have the Automatic tool changer left to do. All the other drills vert horiz had no problem with. I am building my plc program in Linuxcnc almost done for the tool changer.
    this is not a very complicated retrofit. There is alot to it but not that much. Just alot of inputs and more outputs. Even got my zones worked out with the green buttons and the safety sensors... It was a fun one to do.
    I am doing some detailed calibration on the axis.
    The Yawasaki drives are amazing and buiklt like tanks. Easy to interface with Linuxcnc, that was the easiest part. The Inverter for the spindles was pretty easy also. The worst part was figuring out the startup logic.
    After that it was a piece of cake. Could probably do the next one in two weeks or so.
    You will have fun if you choose a capable controller.
    Oh yeah, I have to do my button panel also.
    Aug 2005
    128
    Cut my first pieces on the BS 346. Wow what a machine. I was 64th inch off @110" will regulate that tomorrow. Just a matter of scale for that axis.
    Now, to do the ATC....
    Aug 2005
    128
    First job completed on the new machine. The machine is not finished yet but couldnt say no to this little contract.
    Machine ran real nice and smooth. More accurate than i can measure. I quoted 5.5 hours and the machine finished the job in 2 hours. The cut was in hdpe 1.5" thick and the finish was amazing....
    Attached a photo. How do i place inline?
    May 2007
    7
    I recently got a similar machine, a Biesse Rover 342, and already hate the built in control. Will probably also convert to LinuxCNC. Not quite sure how to handle all the spindles and stuff though.
Page 1 of 2 12
  1. Biesse Rover 342
    By TiagoP in forum CNC Machining Centers
    Last Post: 01-14-2024, 06:20 AM
  2. Biesse Rover 22
    By paul sharpe in forum Education - Teachers and Students Hangout
    Last Post: 09-22-2013, 09:35 PM
  3. Biesse Rover 30 LS
    By andreaslederer in forum Community Club House
    Last Post: 08-02-2013, 06:46 PM
  4. biesse rover 20
    By paulhayden in forum Biesse
    Last Post: 11-08-2012, 12:07 AM
  5. Rover 35 (Biesse)
    By dilmah in forum Biesse
    Last Post: 11-05-2010, 02:31 AM
