603,425 active members*
3,151 visitors online*
Thread: npt threads
Results 1 to 14 of 14
    Mar 2004
    Unhappy npt threads
    hi can anyone give me an example of a 4 inch npt thread program for fanuc. thanks
    Apr 2003
    416
    Are you turning or milling the threads? Also are they ID or OD?
    Bill
    Mar 2004
    i'm turning the thread on the od. i'm using a single line G76 but i have no data on npt threads.
    thanks
    steve
    4826
    You don't have Machinery's Handbook? Shame, shame
    The taper of all National Pipe threads is 3/4" per foot on the diameter, which translates into .0625" change in X for every inch of Z travel.
    The effective thread length for 4" NPT is 1.300 inches. Supposing you begin .2" in front, the amount of taper in 1.5" is .09375", which is the amount you would use in your G76, and here I'm guessing, parameter "I" would be either .0469 (if I is a radial value) or else .09375 if it is a diametral value.
    The pitch diameter at the beginning of the external thread is 4.33438". This can be measured using the "two wire method", if you are accustomed to using Peedee wires to check.
    FYI, All pipe threads from 2.5" pipe on up, are 8tpi.
    Jan 2004
    92
    Sorry Scuba Steve,
    I was out for a couple of days. Here is the format we use for OD NPT threads. You can use Hu's info above. This example is for a 1" - 11 1/2 NPT.
    T0900G97S1800M03(THREAD)
    G00G40X1.375Z.3T0909
    G76P020160M08
    G76X1.1219Z-.60R0.0231P570Q130F0.08696M24
    Z0.3
    G00G28U0
    Z1.0
    M05
    M01
    Gunner
    Mar 2004
    thanks to all it really helped:rainfro:
    Feb 2004
    45
    Hey Scuba, anytime you need something just give me a shout I would be more than happy to help anytime ...goes for anyone else out there also.
    Oct 2003
    38
    I've been doing NPT threads recently which is a bit of a bar steward as the relevant info isnt in the Metric Machinists Handbook.
    Bloody yanks
    Feb 2004
    45
    prolly because npt are National (american) Pipe Threads . Metrics would be BSPT or British Standard Pipe Threads
    4826
    AFAIK, I don't think the metric system even knows about any kind of taper pipe threads. Straight pipe yes, tapered, no. And that, ladies and gentlemen, is why the Imperial measurement system is superior
    But, I could be wrong.
    Oct 2003
    38
    Yeah, you are
    We have the BSP (British Standard Pipe) and also a tapered version of it, the BSPT (British Standard Pipe Taper)
    Imperial, Superior ?? Hahaha #
    The Metric programming system on a Fanuc uses a 3/3 format. 3 digits before and after the decimal point. As far as i'm aware the Imperial system uses a 3/4 format. The 4th digit on the imperial system represents a Tenth of a Thou which is 2.54 microns whereas the 3rd digit on the Metric system represents 1 micon making our system 2.54 times as accurate
    4826
    Isn't it funny how all those "metric pipe threads" are so and so many threads per inch, in whole numbers?
    Oct 2003
    38
    Yeah, even in our Metric Handbook quite a few of the threads have the info written down in Imperial and we have to convert it.
    Oct 2003
    263
    Here's a free program (no tricks) that has detailed info for 192 screw threads, including NPT. One click toggles inch/metric data format. I have an updated version with data for about 1000 threads - planning to charge $20 for it.
    http://dl.winsite.com/bin/downl?14000000036793
    Mike Rainey
    [email protected]
  1. BALLSCREW nut threads?
    By Trapper14 in forum Linear and Rotary Motion
    Last Post: 04-13-2005, 06:49 PM
  2. strange bearing preload threads on ball screw
    By mxpro32 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-11-2005, 03:07 AM
  3. Clifton Motor Threads
    By dowling177 in forum Servo Motors / Drives
    Last Post: 02-08-2005, 01:19 AM
  4. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 03:27 PM
  5. npt threads
    By brtlatjgt in forum Uncategorised MetalWorking Machines
    Last Post: 10-24-2003, 04:42 AM
