586,110 active members*
3,392 visitors online*
IndustryArena Forum > CAM Software > CamBam > moving the cambam tool paths
    Jan 2017
    new user needs help with cambam - I have just about mastered putting tool paths on to profiles but im having trouble moving tool paths where cambam put them . is this even possible to move? eg on a circle it puts the lead in at the top instead of the bottom which produces more travel time and the next profile the same and so on.
    I have looked for tutorials but not much luck checked the cambam documents and they are not much help either.
    thanks for a help
    Dec 2013
    5717
    Re: moving the cambam tool paths
    Let's say that you have a series of circles to cut out. CamBam allows you to set the start point of the series using the Start Point and clicking on the layout. But if all of the circles are in the same MOP, then CamBam will choose what it considers the best path for the rest which is not always the most efficient IMHO. The way around this is to put each circle in it's own MOP and set the start point for each. You can copy and paste the MOPs so this is pretty easy to do.
    On the other hand, for $149, CamBam does a fine job. You could buy a seat of MasterCam for around $8500 and it still does stupid stuff.
    Nov 2008
    412
    Why don't you post this on CamBam forum. I'm sure, the people who know it will be able and happy to help you with your questions.
    CamBam - Index
    Forget about global warming...Visualize using your turn signal!
    Jan 2017
    9
    Quote Originally Posted by stevecam View Post
    thanks for a help
    Me to I m new in CamBam and new in CNC
    In the last 3 weeks I tried many cad cam software and CamBam is the easiest for me to work with
    I do not know if there is a bug for circle or arcs in CamBam but when I simulate the toolpath on my object the toolpath goes outside the arc instead to stay in
    Dec 2013
    5717
    In CamBam, when you create a profile operation, you have to choose Inside or Outside. Look at the second line from the top in the MOP setup.
  1. Replies: 9
    Last Post: 01-01-2014, 06:47 PM
  2. Moving CAMBAM to a new PC?
    By Dougal in forum CamBam
    Last Post: 10-09-2012, 01:50 AM
  3. Moving Mazatrol paths into an external computer
    By gangzilla in forum Canadian Club House
    Last Post: 09-25-2012, 04:21 PM
  4. moving a part in the cambam field
    By wantsout in forum CamBam
    Last Post: 10-23-2008, 05:11 AM
  5. 3d tool paths
    By ginamc in forum OneCNC
    Last Post: 03-19-2005, 06:17 PM
