588,616 active members*
4,573 visitors online*
Results 1 to 10 of 10
    Nov 2007
    71
    Please post images of a brand new S6 or T130 laser tube
    Hello Everyone,
    Is there anybody out there that might be able to photograph the ends of a 130watt 80mm dia. laser tube from Reci or SPT?
    I purchased a tube and I am attempting to find out if I was sold a faulty tube, or a used/damaged tube or if it is infact new. I have nothing to compare to and there are very few detailed images online.
    I am after close up, focused , well taken images of both the anode and the cathode as well as the emitters at each end that are inside the reaction tube.
    I would be grateful if someone could help. In the mean time I will do what I can to help out whoever might need help themselves...
    Thanks in advance.
    Cheers! SW
    Jul 2016
    7
    Re: Please post images of a brand new S6 or T130 laser tube
    Hello SW
    Have a nice day!
    This is Lei from DWD Mechatronics Co.,Ltd,used to be service engineer of cnc router before being a salesman,i attached one picture ,this is reci 130w which i bought for my clients, please check if it can help you . If you met other machine problems about cnc router or laser, you can contact with me ,i will try my best to give you solution. My mail is :[email protected], and whatsapp: +86-15621880878. ThanksClick image for larger version.
    Nov 2007
    71
    Thank you for the image. unfortunately I require images of both ends of the tube. I would like to see what the outer metal connector/jacket looks like and also the emitters inside the reaction chamber.
    Thank you again..!
    I will attempt to make contact with you shortly.
    Aug 2016
    45
    Hello,
    I'm Emily from SPT laser, manufacturing co2 laser tube.
    Below is the tube ends of T130.
Name:	T tube ends.jpg
    Emily
    Nov 2007
    71
    Quote Originally Posted by SPT-Laser View Post
    Hello,
    Emily
    Thank you Emily.
    Can you show side view image of anode and cathode?
    If a tube is brand new and not used is there discoloration on cathode? yello color from heated metal? Thank you for sharing
    Aug 2016
    45
    Hello,
    Send me the picture of your tube ends, I will see.
    Nov 2007
    71
    I have these photos. I can take better if needed....
    Attachment 356148Click image for larger version.
    Aug 2016
    45
    It seems ok from the picture you sent me. It's not SPT tubes
    Nov 2007
    71
    no Emily.
    This is RECI tube.it is supposed to be new and never used. I bought it a year ago. I never energized it and now when I try.it does not lase. So i bought a junk tube. I dont know what chance I have for a warranty replacement as company I bought it from says...11 month warranty. Even though I never use it. I am sad.
    I am sorry to hear this.
    If some laser tube are not sealed very well, the laser tube leaks gas gradually. The laser tube power will be decreased gradually. People could not found this problem even they test it before sending out. That's why the laser tube die even if you don't use it.
    If the laser tube is sealed well, you can still use it after storing two years.
    Thanks.
    Anna
    [email protected]
    [email protected]
  1. As a Laser Tube Manufacturer, How We Test Laser Tube before Shipment
    By SPT-Laser in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-12-2017, 08:12 AM
  2. Laser tube supplier in the UK for chinese laser tube
    By Philjay86 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-24-2016, 08:12 AM
  3. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  4. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
