586,032 active members*
3,010 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > CUSTOMER MODS ON MILL TURN BENCH
    Dec 2007
    77
    A customer sent us some pictures of a modification he did to his bench. Real nice work. He used solidworks for the design and says he can supply the files for anyone wanting to make one themselves.
    Attachment 347658
    Attachment 347660
    Attachment 347662
    Attachment 347664
    Attachment 347666
    Quote Originally Posted by JTJT View Post
    That looks SOLID. Well if there was ANY problem with rigidity, it's gone now!
    I appreciate you posting these things JT, I have an old 12-22 I bought used in the '90's and if a couple projects work out right I hope to be upgrading!
    May 2016
    16
    Re: CUSTOMER MODS ON MILL TURN BENCH
    I'd love to get a copy of the drawings for this mod. How do I get in touch?
    Jul 2004
    103
    Any way to get the file on this. It would be a great upgrade.
    Jun 2015
    4154
    hy just sketch a table, from profiles ( square and L, thickness >=5 ), that is strong enough to hold all your toolings + machine
    on the final shelf, where the machine is, make sure that the profile is not higher than the shelf surface, or it will be harder to clean it, and there will always be chips at the corners
    instead of 4, use 6 'pads' ( with adjustable height ) to make contact with the ground ( thus 2 more in the middle ), and be sure that those can handle uneven terrain, even if your floor is flat, because the welded structure may be buckled
    enough ground clearance, for a forklift and/or hand pallet truck, etc
    cut a few holes, to assure fresh air inside the cabinet
    break sharp edges, paint it / kindly
    ps : if you wish to truly go next-level, mask all the screws, and use welded nuts
  1. Replies: 0
    Last Post: 04-01-2016, 07:55 PM
  2. Replies: 0
    Last Post: 04-01-2016, 07:52 PM
  3. Pro- Bench Lathe & Pro Bench Mill Drill
    By tw-bob in forum News Announcements
    Last Post: 06-06-2014, 02:32 AM
  4. EMCO PC TURN 50 Bench Top Retrofit
    By remcb in forum Vertical Mill, Lathe Project Log
    Last Post: 01-16-2009, 02:12 AM
  5. Looking for turn key bench top engraver
    By xyzer in forum Engraving Machines
    Last Post: 07-26-2007, 08:57 PM
