603,942 active members*
3,295 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan 2000sy fanuc 31i (2010)
Results 1 to 11 of 11
    Sep 2005
    280
    Can't get the M250 to work, set the #51-0 keep relay to 1 and no luck, whats the trick? What am I missing?
    Nov 2013
    65
    Re: Doosan 2000sy fanuc 31i (2010)
    Look through the ladder and see if you find any mention of the M250 code? It's possible your lathe doesn't have the service mode function. I believe that is the only reference I found to the code in all the documentation that came with our machine. It works on my Puma 300. I'll look tomorrow at the documentation for my machine and see if I can find anything to help you.
    Brent
    Feb 2013
    796
    What is your ladder version?
    Doosan Service Technician
    darryl.hardt@doosanmt.com O:973-618-2461 M:973-803-9479
    Sep 2005
    280
    Not sure, how do you find it? thanks
    Feb 2013
    796
    It is in the field "program drawing number" in the <TITLE> Page, inside the <SYSTEM> Key
    Nov 2013
    65
    Here is how I found it on my machine.
    Hit the "SYSTEM" button then arrow over till you see "PMC CONFIG" hit that soft key, then the "title" button.
    My program drawing NO. looks like this.
    PM24S0IDB10, PM24DB10. MEM
    if that helps?
    Sep 2005
    280
    Thanks, I'll check it out and get back to you with that number, Hey while I got your ear, what parameter is needed to change the absolute position on the program check screen (or any screen for that matter) to show the programmed axis numbers (X Y Z ) without the tool offset showing, looking through the book I see 3104.6 or 3129.1 haven't try'ed them yet, maybe you know? I don't care what the offset is, I just want to see the programmed numbers. thanks again
    Sep 2005
    280
    Okay, this is the ladder number: PM25S31AA6S1, PM25A6S1 and I found the parameter I was looking for it was the 3129.1
    Feb 2013
    796
    M250 exists on your ladder.
    You need to be in MDI.
    M251 should be off
    NRST=0
    M32=0 (M30/M02 not happening)
    K12.0=1 (Keep Service Mode = Allow Service mode)
    K10.7=0 (Non Technomech)
    SA=1 (Servo ready)
    Note: service mode will turn off if ANY of the following happens:
    Go Out of MDI, activate M251, M2 or M30, Press NC Reset
    Sep 2005
    280
    Thanks for the reply, I'll give it shot and let you know. you use the M250, can you move the tool around while the spindle is running and door open for ex. setting a Z zero on a part ?
    Sep 2005
    280
    The M250 works! thanks for the help
  1. Doosan 2000sy coolant pump
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 02-16-2012, 05:39 PM
  2. Replies: 6
    Last Post: 01-31-2012, 04:34 AM
  3. Doosan 2000sy
    Last Post: 01-28-2012, 01:18 AM
  4. Doosan 2000sy not on center
    Last Post: 01-09-2011, 11:06 PM
  5. 2006 Doosan 2000sy Fanuc 18i-TB
    Last Post: 01-30-2010, 03:40 AM
