Re: VFD interface to other equipment.
Originally Posted by
Edgardo_dv
Hi AL, if you are correct, I had read earlier and put a diode according to the diagram, even so the relay does not activate, I am stuck, apparently the signal does not reach port 5 of my Gecko ... I am stuck.
If you can't activate a relay, then of course the direct connection will not work either.
Using the direct connection output is identical to the output on a SSR.
Al.
Albert E.
