603,855 active members*
3,808 visitors online*
Results 1 to 6 of 6
Threaded View
    Feb 2004
    466
    Trying to identify steppers
    Hi all again.
    As usual I will bug you guys/gals about the junk I collect on the flea market.
    Now featuring two stepper motors, labels read following:
    1st:
    ( Appears to be Bipolar, 4 wires, 3 Ohm per coil, has a small window at the back end were u can see the wirl spinning)
    MUIRHEAD
    H.F. HYST.
    MOTOR UNIT
    K-164-B
    No 456304
    mF
    TS 1.3 (number 1.3 is engraved besides 'TS')
    2nd: (2 green wires, 2 red wires, greens have 880 Ohm, reds have 350 Omh readings)
    Oriental Synchronous Motor SH1K
    1W 100/110V 50/60~ 0.13/0.13A 1/0.8mF 1500/1800W/M (or H/M?)
    Any takers?
    Should I quit draggin garbage into my house?
    hehehe.
    Konstantin.
  1. power of using unipolar steppers?
    By dowling177 in forum Stepper Motors / Drives
    Last Post: 01-12-2005, 03:10 AM
  2. Just found some steppers!
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 08-15-2004, 01:32 AM
  3. Choosing Steppers
    By RXTurbo in forum Uncategorised MetalWorking Machines
    Last Post: 06-18-2004, 05:21 AM
  4. steppers and current
    By ullbergm in forum CNC Machine Related Electronics
    Last Post: 01-29-2004, 10:24 PM
