586,111 active members*
3,498 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > VisualMill 2017 can't properly open STP file
Results 1 to 1 of 1
    Jan 2017
    4
    I've just made a sample 3D cube with AutoDesk Fusion 360 and then exported it as cube.stp.
    I then opened it in VM 2017, but VM 2017 can't properly open the file.
    VM2017 made flawed faces...
    I tried opening the same file in Rhino 5, No problem....
    I attached the STP file.
    Would anyone explain why this happens?
    Cheers,
    Sawyer
  1. File will not re-open
    By LegoCNC in forum EdgeCam
    Last Post: 07-25-2016, 01:00 PM
  2. How do I get VisualMill to properly handle this?
    By webgeek in forum Visual Mill
    Last Post: 10-19-2010, 05:50 AM
  3. How do I set solid stock properly on this file?
    By billholeman in forum Mastercam
    Last Post: 12-14-2008, 04:36 AM
  4. CANT OPEN FILE
    By reedmiles in forum BobCad-Cam
    Last Post: 12-13-2007, 07:03 PM
  5. Replies: 17
    Last Post: 01-29-2007, 12:08 AM
