586,108 active members*
3,100 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Retrofit - What are "OP" "R11" "S11" etc
    Dec 2008
    41
    Hi All;
    I'm retrofitting a 1980's VMC with Fanuc 6MB electronics. The retrofit is going great, Jon from Pico has been very helpful. I've hit the stage of the project were I'm reverse engineering all the sensors and relays, etc. I have Fanuc documentation but no machine documentation. Hundreds of connections! There are several recurring wire labels I don't understand. Can anyone help with what these "common" wire labels mean?
    "OP" What is this? It seem to work like ground but is not Gnd
    "OL" Same as above
    "S11" This is used lots of places, I think it's power of some type
    "R11" Same as above
    "+24P" This is clearly 24 Volts but what's the P versus N?
    "+24N" This is clearly 24 Volts but what's the P versus N?
    Thanks!
    Apr 2009
    1379
    Re: Fanuc Retrofit - What are "OP" "R11" "S11" etc
    "+24P" This is clearly 24 Volts but what's the P versus N? P= PLUS
    "+24N" This is clearly 24 Volts but what's the P versus N? N=NEGATIVE
    Dec 2009
    953
    R11 as S11 should be 220v as you must have T11 aswell
    if not that i should think is 110v for R and S
    you just have a lot of actuators on triphase 220v for pump and some 110V for electrovalves
    Apr 2009
    1379
    ""OP" What is this? It seem to work like ground but is not Gnd" what do you mean by 'work like ground'? Do you measure 0 Ohms to gnd? It could be the neutral for 3phase.
    Dec 2008
    41
    I spent some quality time in the control box with my Fluke multimeter and ohm'd out some clues.
    OP and OL and indeed "neutral" for the +24V DC. OP comes off a full wave bridge rectifier 180 degrees across the bridge from +24P. I assume OP is then tied to chassis ground in one (and only one) place to avoid ground loops.
    S11 and R11 are 100VAC. Japanese...
    S11/R11, OP/OL and +24P/+24N are each isolated from one another. I'm guessing this is also for ground loops but that's just a guess. Anyone know why this is?
    It's a beautiful old machine, such care in design and wiring.
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Replies: 4
    Last Post: 05-28-2013, 09:20 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
