586,061 active members*
4,589 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Problems with motor stalling due to motor/lead screw alignment
    Oct 2006
    19
    Has anyone had trouble getting the Lovejoy couples to line up?
    I've got everything straight as far as motor mounting to lead screw alignment but the problem seems to be when i tighten the setscrew on the lovejoy couple to my 1/2 inch leadscrew it will either cock slightly sideways or move the screw alignment slightly off center. I'm coupling from 200oz steppers that i got with my Hobbycnc kit and the 1/4 inch couples seem to snug up onto the 1/4 inch shafts of the motors without causing the offset problem. The lead screws are 1/2 inch allthread and are pretty snug going into the 1/2 inch Lovejoy couple but i can't seem to get them to stay straight after tightening the setscrew. Ive tried to grind a flat on the area of the leadscrew where the setscrew will engage but still seem to be getting about 1/16 to 1/8 of an inch of endplay once the spider is inserted. The end result is that the motors will stall after a partial revolution because of the offset. At this point i'm open to any suggestions because i'm really ready to see this whole thing start making some chips.
    Scott
    Jul 2005
    668
    Use a smaller couple half and machine the end of the screw.
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
    Jan 2007
    37
    I've just installed my Lovejoy coupler and I'm getting 93 ipm with no problem stalling or mis-alignment. The end to my xylotex motor is on the flat, my lead screw side is a so messed up on the flat area from trying the straight couplers that I had to use the rounded side and did not grind a new flat. I will do that now that it works nicely. Both of my ends are 1/4" btw.
    Did you check the set screw in the coupler? Maybe it is a manufacture defalt? You said you ground it yourself, are you sure the flat is parallel to the shaft?
    Good luck, I will posting a question momentarily on the other end, how to put nuts that don't slip.
    Aric
    Aug 2009
    8
    Have you tried end machining your lead screws on a lathe?
  1. Stepper motor is stalling
    By bgolash in forum Stepper Motors / Drives
    Last Post: 04-11-2012, 01:31 AM
  2. motor stalling
    By planescott in forum Mechanical Calculations/Engineering Design
    Last Post: 05-06-2006, 03:50 AM
  3. Making a coupler between motor and lead screw
    By nikolatesla20 in forum Mechanical Calculations/Engineering Design
    Last Post: 07-30-2005, 07:05 PM
  4. Problems aligning motor with lead screw.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 02-16-2005, 01:33 AM
  5. coupling motor to lead screw ideas?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 09-15-2003, 05:18 PM
